Latest post 05-06-2009 9:28 PM by Andrew. 5 replies.
Page 1 of 1 (6 items)
  • 10-29-2007 9:44 PM
    • B Price
    • Not Ranked
    • Joined on 07-11-2007
    • Virginia, USA
    • Posts 13
    Beogram RX
    Another question on my RX. As stated in previous posting question, am totally unfamiliar with B&O products, but they are lovely. Just acquired this table, untested. Have been playing it today and am certain it is 1-3 rpm's to slow, being familiar w/the Carly Simon lp played. Is there anything I can do? No B&O techs around here! thanks............what a great site.
  • 10-30-2007 8:42 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram RX
     There's a couple of adjustments from below but why not get the service manual from the download section. It will describe the correct procedure for adjustment of speeds etc. I'm not sure we have the RX manual but the Beogram 2000 manual will fit nicely since it's pretty much the same internals.
  • 10-30-2007 3:04 PM In reply to
    • B Price
    • Not Ranked
    • Virginia, USA
    • Posts 13
    Re: Beogram RX
    Martin, really appreciate the info. Will try this later & post results. thanks so much...........p.s., checked a known  song on 45 rpm and it seemed out of pitch also.
  • 10-30-2007 5:02 PM In reply to
    • Dillen
    • Posts 5,008
    Re: Beogram RX
    Yes, the 33 and 45 speeds are slightly dependent. There's a specific procedure and order of adjusting.
  • 05-06-2009 8:21 PM In reply to
    • B Price
    • Not Ranked
    • Virginia, USA
    • Posts 13
    Re: Beogram RX
    Martin, been a year. Have had serious accident since then and no time to check 0ut table. Have not found a way to adjust the pitch on the turntable. Any help appreciated
  • 05-06-2009 9:28 PM In reply to
    • Andrew
    • Not Ranked
    • Joined on 03-16-2009
    • Melbourne, Australia
    • Posts 49
    Re: Beogram RX
    hey bprice
    you will need to pay the membership fee to join the site and you will be able to download the service manual which should have the procedure to adjust the pitch of each speed.
    Andrew
