Latest post 10-30-2007 4:36 PM by Moller. 2 replies.
Page 1 of 1 (3 items)
  • 10-29-2007 5:11 PM
    BC2 can't play DVD on BV L2800
    Dear Forum,
    I have some problems connecting my BC2 to my old BV L2800 in order to play DVD's on the BC 2:
    When I connect the SCART cables and start the DVD, I cannot get a decent picture on the TV. I floats all over the screen and/or is garbled.
    When I try hitting the control 0 - 9 on the remote, the picture changes but really not to anything better.
    The funny thing is that when I connect my cheap £30 supermarket DVD player to the TV, it just works fine.
    Obviously I have done something wrong - but what? I have also tried fiddling with the SCART / Video settings on the BC 2 but to no avail.
    Is there a solution?
    Best regards,
    Moller
  • 10-29-2007 6:27 PM In reply to
    Re: BC2 can't play DVD on BV L2800
    Set BC2's Video setting to CVBS. Do you use the same scart cable for both DVD players?
  • 10-30-2007 4:36 PM In reply to
    Cheers, Stig - that did indeed solve my little problem. And yes - I did use the same SCART cable for both DVD players ;-)
    Best regards,
     Moller
