Latest post 10-30-2007 11:49 AM by TheMajor. 7 replies.
Page 1 of 1 (8 items)
  • 10-29-2007 9:05 AM
    Beolab 4s left not going on stand by
    Hey guys my left beolabe 4 is going into stand by mode. They are both set to auto. Any ideas?
    Beosystem 7000/6500- Beolab 4000 - Beosound 1 - A8 - Earset 3 - Beo4
  • 10-29-2007 11:25 AM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Re: Beolab 4s left not going on stand by
    TheMajor:
    It could be the remote in the powerlink cable... Try switch the powerlink cables to sort out the problem...
    Regards
    BL8000 MkII Black
  • 10-29-2007 11:49 AM In reply to
    They are PCs.
  • 10-29-2007 12:03 PM In reply to
    • Beolab
    • Sweden
    • Posts 535
    TheMajor:
    They are PCs.
     Try to switch left and right cable to see if it helps then you now if it is the cables or not.. Otherwise it is in the circuit inside the speaker and you must contact your dealer and have a service..
    Regards
    BL8000 MkII Black
  • 10-29-2007 12:33 PM In reply to
    Thanks mate I will try it again, I only bought them yesterday.
  • 10-29-2007 12:58 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Southern CA
    • Posts 137
    When I had mine hooked up with my PC, one of them would always stay on... now with my mac mini they both go off.. not sure why but it really didnt bother me.
    -Alex
  • 10-30-2007 8:36 AM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    That would be because the MacMini will have a much lower noise output in comparison to the PC (Macs generally have much higher quality sound cards built in).
     Weekly top artists:
  • 10-30-2007 11:49 AM In reply to
    Mine is a mac too. I will study the required Japanese and go see them in store.
