Latest post 10-26-2007 3:59 PM by ThePriest. 7 replies.
Page 1 of 1 (8 items)
  • 10-26-2007 2:14 AM
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    Beomaster 4500
    I just acquired a Beomaster 4500 and the sound that it produces is truly outstanding.
    Perhaps I am doing something wrong, but when attempting to program the FM stations I have to push on the Beomaster with all my might to get it to respond…. and then when it does, more often than not it is for the next station.
    Frustrating! Laughing
    Thank goodness I didn’t sell my remarkable Beomaster 2400 which is beyond perfection!
    Am I missing something here?
    Jeff
  • 10-26-2007 4:33 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: Beomaster 4500
    FYI:
    You can use a Beolink 1000: To tune a station press RADIO GOTO 1045, which will give you the station on 104.5 MHz.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 10-26-2007 4:51 AM In reply to
    • Kokomo
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    Re: Beomaster 4500
    Piaf:
    Jeff
    Hi Jeff,
    My 4500 is immaculate, looks superb and produces great sound, however some time ago the touch controls for station tuning stopped responding. As the other response has mentioned, FM tuning can be achieved via the Beo 1000 control, however it doesn't work via my Beo4! If I want to tune stations therefore I have to remove the black glass cover from the unit and touch the controls below. As station tuning is not a frequent need for me this is no problem, just a bit frustrating .
  • 10-26-2007 2:58 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: Beomaster 4500
    Probably the sensors are not making contact properly with the glass. There is a square on the underside of the glass where the sensor must be against for it to work. Often when the glass becomes a bit loose or not fitted properly the sensors won't work. So if your sensor isn't touching the square there is no contact, Also note because the glass slides onto the PC board the sensors bend which is normal. They mustn't be straight up.
     I hope this helps.
    Durban South Africa
  • 10-26-2007 2:59 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beomaster 4500
    If you open up your Beomaster and access the PCB which runs under the glass touch panel you will probably find small metal tubes which run under the corresponding touch sensor areas. Very carefully rub the tips with some very fine abrasive paper such as 1200 grade wet or dry sand paper. This has been a success for me on other B&O equipment such as a CDX & Beocenter 8500 which had this exact problem. I've never owned a Beomaster 4500 but I would strongly suspect that it works on the exact same principle.
    Chris.
    EDIT:- I bow to Francoisvl on this one as he got there first & obviously knows his way around these better than my humble selfEmbarrassed
  • 10-26-2007 3:33 PM In reply to
    • Piaf
    • Posts 409
    Re: Beomaster 4500
    Thanks all, you solved my problem. I also have a CDX, but its contacts are still functioning.
    Jeff  Big Smile
  • 10-26-2007 3:35 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Beomaster 4500
    Ben (francoisvl) and i have had our fair share of experiences
    with replacing the glass panel on Beomaster 3500 / 4500
    Smile
    the plastic "frame of the glass panel :
  • 10-26-2007 3:59 PM In reply to
    Re: Beomaster 4500
    Hi
    Yup I did the same to my Beosystem4500 when I bought it last year.
    I took them apart and carefully cleaned the capacitor dark grey spots with isopropyl alcohol.
    I also heard that when the 4500 hangs on the wall, the front display glass tape could suddenly give after and then the glass could fall down and break, so I changed the tape and the added some super glue also between the glass and plastic frame.
    The capacitive touch works nice again and now I know that the glass will stick on to the plasticframe in the future. Yes -  thumbs up
    Regards Anders
