1st March February 2012
Latest post 07-06-2007 5:51 PM by Alex. 22 replies.
04-21-2007 8:46 AM
TerryM
- Joined on 04-17-2007
- Posts 208
Beosystem 3-does it upscale?
Yesterday,during a demo of a BV 9,I was surprised to be told that the integrated Beosystem 3 does not incorporate upscaling. Is this correct? If so,it is a surprising omission given the alleged sophistication of the Beosystem 3. Not all source equipment embodies upscaling equal to a BV9/Beosystem3.
Corvin
- Joined on 04-16-2007
- Australia
- Posts 124
Re: Beosystem 3-does it upscale?
Yes to the best of my knowledge it does upscale.
Beonut
- Essex, UK
- Posts 89
My BS3 upscales very well, it makes DVD look like HD, and analog and SD TV look nicer too.
My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
Alex
- Bath & Cardiff, UK
- Posts 2,990
Yes, it does a fantastic job of upscaling. From a distance of 4-5m on a 65" display, I struggle to tell the difference between standard definition and high definition other than a slight increase in depth.
So yes, it definitely DOES upscale, and does a much better job of it than my Philips upscaling DVD player!
Weekly top artists:
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Sorry to sound really thick, but what does upscaling mean? Andy T.
Beonut
- Essex, UK
- Posts 89
Andy Upscaling is a method of taking a standard definition signal like analog tv or DVD and using a video scaler to match the pixel count of the signal to the physical pixel count of a high def tv, resulting in better detail and color consistency. Upscaling does not really convert standard dvd into true high-definition images, but a good quality one can do a very good job at it. The BS3 has a very good quality upscaler built into it, so any souce can be upscaled as required to the resolution of the plasma connected. I hope this helps. Peter
Tom
- Luxembourg
- Posts 3,175
Do all of the B&O LCD and plasma screens upscale, or is it just the BS3 and BV9?
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
jandyt: Thanks Peter for taking the time to answer that Would I be right to presume that it estimates what colour it thinks the missing pixels should be, or have I gone off on a tangent? Andy T.
Roughly yes - you can't invent detail that isn't there in the source information although clever DSP can interpolate pixels and highlight edges etc much like enhancing photographs in Photoshop etc.
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
tom: Do all of the B&O LCD and plasma screens upscale, or is it just the BS3 and BV9?
Doesn't the BV-7 upscale to? I mean not the new BV 7 BS3 equipped one! Regards
pedrompinto
- Joined on 04-29-2007
- Lisbon, Portugal
- Posts 239
So, what you're saying is that if i use BS3 with a BV7-40 720p the image quality will be increased in a way that it's almost a 1080p ?
Pedro
"Less is more"
BV7-40 MKII + BL7.2 + BL9 + BL3 + BS4 + BL4 + A9 + Earset 2 + 2 x Beo4 +
BeoCom 5
Emmanuel92
- Joined on 02-14-2007
- Paris
- Posts 2,032
Alex: Yes, it does a fantastic job of upscaling. From a distance of 4-5m on a 65" display, I struggle to tell the difference between standard definition and high definition other than a slight increase in depth.
+1 We recently saw a demo of Star Wars III on a BV4-65: we were not able to tell if it was HD or not !
Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
symmes
- Joined on 04-21-2007
- Freedonia
- Posts 290
Subjective, biased, unscientific opinion
I have seen a number of combinations at our store, and now have the US 7-40. The best picture we get to date is an over-the-airwaves HDTV 720p signal on BV9 and now the BV7-40. Over the air is FAR better than our local cable HD signal. Very slightly less (or the same) is Blu Ray off Playstation 3 into the BV4-50. Oddly enough, a well mastered normal DVD from BeoCenter 2 or BV7 looks nearly as crisp, but it varies widely with the quality of the source. (We demo a remastered Alfred Hitchcock's "North By Northwest", an absolutely amazing picture in many ways). That might be true for Blu Ray or HD-DVD as well, but we don't even mess with them unless a client is specifically interested. Have yet to see a 65" in 1080p, but imagine only the pure size of it would necessitate the higher pixel count.
PS, the built-in HD tuner on BV7 is the best. Where I live, you can pick up 12 channels with a $50 antenna. Ray.
Alex
- Posts 2,990
Re: Subjective, biased, unscientific opinion
Bear in mind this is the BeoSystem 3-based US version. The current (pre-late 2007) version of the BeoVision 7 in Europe is a completely different set internally, and hence does none of this anywhere near as well as the BeoSystem 3 based sets do...
Weekly top artists:
DoubleU
- Joined on 05-09-2007
- Posts 866
Upscaling is fine, but only if it happens once!!! Panels that don't have a resoulution of 1280x720 or 1920x1080, upscaling doesn't make any sense. The intern scaler of these panels has to scale again to the native resolution of the panel. A BV7 has a native resolution of 1366x768.
Only panels with a native resolution of 1980x1080, will have profit, with upscaling sources, like a BV9 / BV4. Most beamers have a resolution of 1280x720 (720p), so upscaling does make sense there too.
kawo
- Posts 516
From my expirience this very much depends on the display and the scaler and deinterlacer of both devices. Sometimes you get a better picture if you feed 1080p to a HD-ready display (1280x720 or so) and the display has to do some "donwsizing", sometimes 575p (PAL) is just better.
With my BS3 conneted to a Full HD Projector on a 2,44m screen a difference is quickly noticable. At this point in time I have to say that the scaler of the Bs3 is quite good, but not perfect. The picture prozessor of my HD-DVD Xe1 from Toshiba with the Reon chip does a better job in upscaling a PAL DVD to 1080p than the BS3 if I feed the signal direct to the projector without the BS3. The best DVD proceccing I have seen sofar was with a Denon 3930 upscaling to 1080p, slightly better than the Xe1 in a direct comparison. Experts have told me that this is the best DVD you can get for money today from a video point of view.
However, very little details you will not see in your day to day viewing expirience! If you are a big fan of test images you should care, if you want to enjoy movies just relax and have fun..... Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
jvezina
- Posts 120
Dear Karsten, do you have the latest software version installed in your Beosystem 3? From what I have read here, correct 1080p output is supported only with the most recent software upgrades. Best regards, Jean Vezina
Alex
- Posts 2,990
Considering it's upscaling an analogue signal (when watching DVD), the BeoSystem 3 does a better job than anything I've ever seen. However, bear in mind that when your DVD player upscales it, it has all the digital information the DVD can spit out, and hence with some clever software can 'fill in the gaps' in a better way than the BS3 can when using an analogue connection.
Weekly top artists:
Beolab
- Sweden
- Posts 535
Alex: Bear in mind this is the BeoSystem 3-based US version. The current (pre-late 2007) version of the BeoVision 7 in Europe is a completely different set internally, and hence does none of this anywhere near as well as the BeoSystem 3 based sets do...
Alex I'm think your wrong here. I spoked to my friend ho works at a B&O shop here in Stockholm. And he had received a intern mail that the BV 7-40 are going to be Full BS3 equipped!=) Not semi equipped but full like the US version.
kawo
- Posts 516
yes, I have 3.1, however still quite buggy Karsten
Alex
- Posts 2,990
Beolab: Alex: Bear in mind this is the BeoSystem 3-based US version. The current (pre-late 2007) version of the BeoVision 7 in Europe is a completely different set internally, and hence does none of this anywhere near as well as the BeoSystem 3 based sets do...
The BeoVision 7 isn't BS3 based yet, but it will be soon, as you say...
Weekly top artists:
Page 1 of 1 (23 items)
