Latest post 11-02-2007 10:12 AM by MartinW. 4 replies.
Page 1 of 1 (5 items)
  • 10-25-2007 1:42 PM
    • Redmax
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 2
    IR code setup
    It's been a few weeks since I saw my dealer setting up my IR codes and now I'm in a position to configure my own Wink I'm struggling to remember how it was done.
    Could I have a reminder please?  Perhaps the best way is to pick a real life example - for example how would I set up the codes to go to the recorded programmes section on Sky +?  On a Beo 4 this would be Go, 1, Green...
  • 10-27-2007 6:37 AM In reply to
    • Redmax
    • Not Ranked
    • Posts 2
    Re: IR code setup
    Help! Anyone?
  • 10-27-2007 9:44 AM In reply to
    Re: IR code setup
    You have a PM
    Regards Keith....
  • 10-28-2007 11:18 AM In reply to
    Re: IR code setup
    Hi BEO5 users
    I have been to the dealer 4 times now to get it configured right.
    I also have the lintronic box at home, controlling other hardware than my B&O.
    BUT STILL not working correctly at controlling all the hardware.
    Anyone with the config software install package, i would really apreciate.Wink
    Regards
    Jacob Just
    \Denmark
  • 11-02-2007 10:12 AM In reply to
    Re: IR code setup
    Hi Jacob, check out my post on Beo5 with Sky + - it tells you how to set up the code for accessing the planner.  (Go-1 then Green)
    If there is anything else you want to do, post it and I will try to help.
    Thanks,
    Martin.
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
