Latest post 10-26-2007 1:06 PM by KingStreet. 3 replies.
Page 1 of 1 (4 items)
  • 10-23-2007 9:56 PM
    A8 Headphones
    How can I tell if my A8s are real or fake?
  • 10-24-2007 12:44 AM In reply to
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    Re: A8 Headphones
    post a picture
    DU BEAU, DU BON, DU BO.
  • 10-25-2007 4:13 PM In reply to
    • Joe
    • Not Ranked
    • Joined on 10-03-2007
    • SoCal
    • Posts 74
    Re: A8 Headphones
    If you bought them on ebay for $40, they are probably fake. Find someone that has a real set and compare the two. The differences will show when side by side.
    Joe
    Its not just a product, its a way of life...
  • 10-26-2007 1:06 PM In reply to
    Re: A8 Headphones
    Fake A8's have a silver end cap on the "arm" - at least all the ones I've seen so far.
    Other diffferences ( apart from crappy sound !! ) are the writing is not printed cleanly, the wires are lower spec, the leather pouch is plastic, and there is noticeably low grade packaging.
    As per the earlier post, with any online BeoBargain, if its too good to be true ( and £40 for A8's is too good to be true ) its generally because its a rip off.  Or stolen.
    Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
