Latest post 04-26-2007 9:35 AM by Corvin. 10 replies.
Page 1 of 1 (11 items)
  • 04-21-2007 7:15 AM
    • wood
    • Not Ranked
    • Joined on 04-20-2007
    • Posts 42
    • Gold Member
    BeoSystem 3
    I plan to buy a BeoSystem 3 and like to know all about the connection of "non-B&O"-equipment. I will connect: Pioneer Plasma PDP506-XD, the upcomming Reelbox Avantgarde (SAT-Rec with build-in HD-Recorder and DVD-Player from Reel-Multimedia, Germany) and of course my BeoSound4.
    I like to control all this units with Beo4. My questions: is this possible? how does this work?, whats about PUC (Peripheral Unit Controller)? can i do the configuration-work by my self? are there pre-configurated units in the system and exist a list of them? whats about the "Ctrl-sockets"?
    I'm happy to receive all possible information about BS3, especialy connection non-B&O units and the configuration/setup-work.
    thanks in advance
    wood
  • 04-21-2007 7:55 AM In reply to
    Re: BeoSystem 3
    I have put the user manuals on site - you are silver so can get at them. There are two lists you need to look at - the DVD controller and the STB controller. The big problem is that both tend to list out of date equipment. I would also see what Lintronic can offer in the way of operating your extra equipment as it may be better.
  • 04-21-2007 7:14 PM In reply to
    • Corvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Australia
    • Posts 124
    Re: BeoSystem 3
    I am just finalising my set-up at the moment using the Beosystem 3, Pioneer Plasma and a Samsung HD STB and HDD. I now have all working through the Beo4 using Lintronic.
     Today i will be trying to find what i need to control the Playstation 3 with IR and intergrate that also.
    All works well except for 1 little quirk with speaker switching that io posted elsewhere here.
  • 04-22-2007 8:04 AM In reply to
    Re: BeoSystem 3
    Playstation 3 controlling over IR? When you find a solution, please let me know. I only got the Info that you need Bluetooth to control the PS3 (as well when you playing BD ).
    thx
    Thomas
  • 04-22-2007 11:14 AM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BeoSystem 3
    Yes, the PlayStation 3 is controlled via Bluetooth, NOT Infra Red. If you can come up with a solution, it would be good to know.
     Weekly top artists:
  • 04-22-2007 12:44 PM In reply to
    • Pushkin
    • Not Ranked
    • Joined on 04-19-2007
    • London
    • Posts 50
    Re: BeoSystem 3
    The PS3 has IR functionality as well as bluetooth.  Sony have just lauched their own IR remote for use with the PS3 - have a look at this link - http://www.remotecentral.com/articles/ps3-ir-remote.htm
  • 04-22-2007 10:19 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: BeoSystem 3
    I purchased an OEM unit connected via usb but am having trouble with the Lintronic learning the IR codes. I'll keep trying
  • 04-25-2007 11:36 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: BeoSystem 3
    purchased an aftermarket stand that connects via usb and has a ir receiver + remote.
    All working ok but has limited control. Can't turn the system on/off but can select menu, play, stop, pause, rewind, fastforward s after turning on and putting the movie in, all can now be controlled with the Beo4
  • 04-26-2007 7:55 AM In reply to
    Re: BeoSystem 3
    nice work.....
    The more I learn about BS3, the more convinced I am that is a route I might take....
  • 04-26-2007 8:16 AM In reply to
    Re: BeoSystem 3
    I'm totally convinced this is the "new" way of planning and purchasing an AV system for the house. Begin with the BeoSys3 control hub, and then attach what one needs to that hub.
  • 04-26-2007 9:35 AM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: BeoSystem 3
    Precisely my thinking and action. I couldn't be happier all is working well.
