1st March February 2012
Latest post 11-08-2007 5:37 PM by Anonymous. 14 replies.
10-23-2007 4:45 PM
Christian
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 626
My Beo5 locks into a blinking mode - HELP
Hey My Beo5, which has been working fine until now, has developed a strange fault. It starts blinking (both the ball and the screen), and at the same time it locks the keys, and I can do nothing. After 10-20 seconds the blinking stops, due to the dimming function, but I have to wait another 2 minutes or so, before I can turn it on again. While blinking I can see the one of the two IR emitters are lit. I have been setting it up my self, but the fault does not seem to be connected to any of my "home made" buttons. Have anyone experienced anything similar?
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Re: My Beo5 locks into a blinking mode - HELP
Oh eck! My guess is that it is something you have done inadvertently, Christian. You say the IRs are sending some kind of signal, try to find out what, and that might give you a clue as to what you have done wrong. Perhaps you could try changing channels or switching between radio and CD with your Beo4 whilst the 5 is blinking and see if it conflicts. The other thing you could do is to go into the SETUP menu, CONFIG, DEFAULT, STORE and see if it cures the blinking. Don't worry, you won't lose your custom settings. Andy T.
Christian
- Posts 626
It does not activate any equipment, TV - BeoSound - light - etc., but at the moment I cannot make it fail. Very strange. It seems, however, that it needed recharging. I have tried to store the default, but it resat the Beo5 completely. All custom settings was lost, but I have the setup file stored, so no worries.  It is now placed in the charger, as the battery was completely flat. I suspect that this is the real cause, but the behavior is very strange...
Jandyt
- Posts 13,004
Christian: All custom settings was lost,
I'm shocked to hear that Christian. Whilst I was pondering your post, I switched between custom and default twice without losing anything. Andy T.
Christian
- Posts 626
So I can switch back to custom setting? - Just checked, and the custom settings was "recovered".   I feel like an 80-year old woman: Ohhh my remote is to advanced for me..... (Couldn't find the wall bracket for my EarSet 2, it was hiding in the box. Called the dealer, only to find out that it had been there all the time...) Thanks.
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Christian, In the apparent failing condition was there a small red light visable on the back of the Beo5. If there was, then the battery needs recharging. Leaving the Beo5 connected to the USB appears to quickly discharge the battery.
PhilLondon
- London
- Posts 2,545
Keith Saunders: Leaving the Beo5 connected to the USB appears to quickly discharge the battery.
Instead of charging it like other USB devices??? oh beo...
Christian
- Posts 626
There was a red light visible in the back, looked like one of the IR emitters. It is now placed to charge until I get home from work, and I will report if the problem persist, and if it seems to be related to low battery.
Santiago
- Switzerland
- Posts 3,286
wtlc2zpx: Keith Saunders: Leaving the Beo5 connected to the USB appears to quickly discharge the battery.
In addition when beo5 is connected to the USB, in the upper screen also appears the word "Charging"
Christian
- Posts 626
Santiago: wtlc2zpx: Keith Saunders: Leaving the Beo5 connected to the USB appears to quickly discharge the battery.
Maybe it is supposed to be charging, and it might be a software bug. Like the thing, that you have to turn it off, before it will charge.
Santiago
- Switzerland
- Posts 3,286
Christian:Maybe it is supposed to be charging, and it might be a software bug. Like the thing, that you have to turn it off, before it will charge.
I've not yet controlled indeed if the beo5 really charge the battery in USB mode or not... but I'll do a try. However I have never been forced to turned it off before put it on charge, and always has charged correctly.
Santiago
- Switzerland
- Posts 3,286
Santiago: Christian:Maybe it is supposed to be charging, and it might be a software bug. Like the thing, that you have to turn it off, before it will charge.
I've finally done the test, and when the beo5 is connected to usb, it charges!!! so what the screen shows is absolutely true. But the charging is very very slow, only the half of a battery in 8 hours, so 4 times slower than using the transformer charger. Regards.
Christian
- Posts 626
Glad to hear that it does charge by USB. Did not have the patience to see any reaction. Now I know why  .
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
When connected to usb it charges with only 90mA ZZZzzz  ..
mine dont lock up but the sensi touch on the glass display sometimes does not react to touch, I also find that sometimes when pressing the hard keys at the bottom of the screen these do not work, so the only way to stop this is to power cycle the thing. appologies for grammer, i was 2 bottles of red wine down while typing this JOn
Page 1 of 1 (15 items)
