Latest post 10-23-2007 2:20 PM by s329. 3 replies.
Page 1 of 1 (4 items)
  • 10-23-2007 11:16 AM
    • s329
    • Not Ranked
    • Joined on 10-23-2007
    • Posts 2
    BS4 and A.AUX problems with my sony XBR
    A definite newb question so all your input would be much appeciated.
    I recently purchase a BS4 and BL3 and absolutely am in love with the system. sitting next to this handsome system is a sony xbr5.
    i used RCA cables from the tv to the BS4 and as soon as I get it to A.AUX, the speakers make a very distorted buzz noise and just continue.  This is when the tv is playing a movie so i'm assuming the audio out is outputting sound via the RCA cables.  am i doing something wrong with setting up the A.AUX?  Am I missing something?
     Lastly, unrelated to this issue, everytime i turn on the BS4 to play a CD when the lights on the BL3 go from red to green there is a very slight "tick" sound, almost indicating power turning on the speakers, it's extrememly faint, but i wasn't sure if this was expected.
    Thank you in advance for all your help.  this forum convinced me to purchase this system and I enjoy it more than the TV.
  • 10-23-2007 12:48 PM In reply to
    • dljones
    • Not Ranked
    • Joined on 06-23-2007
    • Richmond (Surrey)
    • Posts 13
    Re: BS4 and A.AUX problems with my sony XBR
    Hi Can't comment on cables as I'm not technical so don't know correct name although with my sytem BS4 and BL8000's I just have standard audio cable (red plug and white plug).
    Re the tick I get the same when switching on or off so presume this is normal
  • 10-23-2007 1:51 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Have you tried to connect a source other than your T.V. to the A.Aux connection. If you have and it works O.K. I would say the problem is with the T.V. Might also be worth trying anothe cable. A few years back after moving some furniture around, I required a longer cable to connect my PC o my system. When I connected a new cable, I had the same problem. Very loud buzzing from the speakers.
    CraigSmile
  • 10-23-2007 2:20 PM In reply to
    • s329
    • Not Ranked
    • Posts 2
    Thank you for the comments so far.  I haven't had the chance to check any other input device so far.
    I had a pair of monster 400 interconnect RCA cables lying around the house so I assumed that they would work fine.
    Why do i get this eery feeling that it's the damn monster cables that are causing this problem?  I might just stop by a local radio shack on the way home and get the standard red/wht cables.  If they work then I'll be extremely happy.
