Latest post 10-31-2007 3:16 AM by Flappo The Grate. 1 replies.
Page 1 of 1 (2 items)
  • 10-22-2007 4:57 PM
    Hmm [^o)] Moisture or condensation inside new iMac screen??
    I heard many complains about condensation inside the new iMac 24' screen.
    A large patch of condensation on the inside of the glass screen bottom right hand corner has been reported by recent customers.
    It appeared about an hour after the first boot and took about 4-5hours to disappear. For some it reappeared later on.
    Some think it shows when the iMac (now with a hard metal case) has been cold and in a storage room for some time. Then it's rapidly heated up after being switched on for the first time causing the condensation.
    Others are speaking about environmental conditions (cold area or a humid area).
    Could there be outgassing of chemicals used in manufacture that could be responsible and if so, why the same right lower corner for everyone so far? There must be a rational explanation. Any ideas appreciated.
    Now, knowing the glass panel is attached with magnets, should it be the main reason of this issue ?
    Some customers went to Apple Store to let them know about this problem. They got informed that they'd had two iMacs returned with condensation under the glass panel.
    By the way, this issue seems fixable (by Apple) as the glass panel is removable:
    http://discussions.apple.com/thread.jspa?messageID=5125537&#5125537
    I am crossing my fingers as my new iMac 24' is being concerned with this condensation issue....
    Guy
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 10-31-2007 3:16 AM In reply to
    Re: Moisture or condensation inside new iMac screen??
    i had a 20" imac that suffered with screen discoloration , that model was due to the back panel being poorly made in the factory
    pesonally i wouldn't buy another mac all in one until they start using led backlights or get their act together
    i've got a mac pro instead , noisier but you can connect it to your tv and use that as a monitor
     that or a mac mini attached to say a bv8 or 7 would be a million times better than the imac
     you lose front row on the pro , but that's overrated imo , just invest in a long usb cable or bluetooth adaptor and use itunes etc from your sofa / bed
    popgear is grate™
