Hi All,
Can anyone answer a few questions re the beomedia 1
What is the HD capacity?
Does it work with non B&O TV's?
Does the TV have to be LCD?
How does it connect to the TV and HIFI i.e. which cables?
To use it in other rooms, do you need a TV in each room to navigate your music?
How does it compare to some of the wireless streaming systems which are available? bearing in mind my main aim is to use it for music storage.
Can you add external HD's?
Cheers
Graeme
