Latest post 10-26-2007 6:53 AM by cozza. 3 replies.
Page 1 of 1 (4 items)
  • 10-22-2007 10:11 AM
    BEOLINK 7000 YELLOW CAPACITORS REPLACEMENT???
    HI GUYS!
    MY BEOLINK 700 STOPPED RESPONDING, I WAS TOLD THE SMD CAPACITORS NEED TO BE REPLACED.
    WHAT TYPE OF  SMD CAPACITORS SHOULD I BUY AS A REPLACEMENT? AND ALSO SHOULD I REPLACE ALL 5 OR JUST THE 2 VERTICAL ON THE LEFT FROM THE  IR TRANSMITTERS?? WOULD YOU HAVE ANY NUMBER AND (OR) SPECS WHEN I GO TO THE ELECTRONICS STORE TO TELL THEM WHAT IS THAT I NEED?
    AGAIN MANY THANKS FOR YOUR ADVISE?
    Filed under:
  • 10-23-2007 8:17 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: BEOLINK 7000 YELLOW CAPACITORS REPLACEMENT???
    Moved to "Workbench" !!
    Big Smile
  • 10-24-2007 2:28 PM In reply to
    Not all 5 capacitors are always defect... already one of them can cause this bad effect. But it makes no sense, exchanging just one of them... hmmm, which one one is now the defect one? You can't test or measure it. So exchange all of them.
    The parts are cheap, we are talking around 50 cents...and 2 hours skilled work on very tiny parts. One miniature 1uf capacitor is around 7 cents...
    The necessary values are all printed on the original SMD parts, i dont remember now the values, but every repair shop has this parts on stock.
  • 10-26-2007 6:53 AM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    The two capacitors inside the IR receiver metal shielding are prone to failure in my experience. The value is 22 microfarad, 16 volt. I wouldn't replace the others unless they tested bad with an ESR meter.
