I wouldn´t say Apple copied B&O. The idea of hiding the display behind a glass screen is neither new nor really exclusive or patented to B&O. The other way around you could say B&O copied everybody else by forgetting the glass on BV8.More interesting is the question how (or even if) Apple solved the problem of dust behind the glass, as the screen looks glued to the frame on the iMac (and so not easy to dismantle). And with all the hot components in the housing there will be quite a lot of air to blow around...only time will tell, i´m afraid.Regards, beoberlin
