eddy:geachte bang & olufsen liefhebbers
ik heb onlangs een stel luidsprekers beovox 5700 op de kop kunnen tikken, maar er is wel wat werk aan
is er iemand van jullie die ervaring heeft met de beovox 5700 klankkleur,kwaliteit,eventueel herstelling en welk merk luidsprekers er in die tijd inzat ik denk zelf Goodman of philips en door welk kan ik deze het best vervangen?
groeten Eddy
Hallo Eddy,
Welkom bij BeoWorld
Zelf heb ik geen ervaring met Beovox 5700,
maar hier zijn de specificaties, misschien dat je er iets aan hebt.
Beovox 5700:
DIN power handling capacity 60 watts
Music power handling capacity 100 watts
Impedance 4 ohms
Frequency range 35 - 20,000 Hz
Harmonic distortion < 1 %
Sensitivity 3 watts
Net volume 45 litre
Woofer: 22,5cm and ABR 25cm
Mid-range 6cm Dome
Tweeter 2cm Dome
Crossover frequency 600 - 6000 Hz
Dimensions W x H x D: 36 x 66 x 30 cm
Weight 22.5 kg
Beovox 5700 Types: 6229 (1972 - April 1974); 6253 (1972 - June 1975)
Beovox 5702 Types: 6257 (1971 - Jan 1975); GB 6251 (1971 - Oct 1973)
Beovox 5700
high fidelity loudspeaker was of studio monitor
quality with minimum distortion and maximum power handling capacity.
The loudspeaker was designed to handle 60 watts RMS or 100 watts
music power with a distortion of less than 1% over the entire frequency
range of 25-20,000 Hz. In order to produce these qualities, Beovox 5700
was fitted with a 25cm ABR (Auxiliary Bass Radiator) unit and a 25cm
bass unit which together produced a clear powerful bass reproduction.
Its mid-range dome was 5,5cm in diameter and its dome tweeter was 2cm.
Dispersion was 160 degrees.
Trumpet stand
Owing to its size, Beovox 5700 could be preferably used as
floor-standing speakers. For this reason Bang & Olufsen designed
the trumpet stand, type 8906007. This stand had a top on which the
loudspeaker could be placed, not only elegantly, but also practically
so that a good sound dispersion could be achieved.
