Having a problem with my laptop! I set the screen resolution to 1023 x 768 (Which is recommended by the manufacturer as well)
Problem is 99% of the time the computer will almost be finished booting (correct screen resolution will be showing) when it will reset itself to to the lowest resolution! I have tried everything! Once or twice it'll load fine but the majority of the time it resets! Of course all my desktop icons go all over the place.
 I hope someone has an idea for me
 P.s. I've checked that the driver is properly loaded.
