Latest post 10-16-2007 3:44 PM by Dillen. 10 replies.
Page 1 of 1 (11 items)
  • 10-16-2007 9:32 AM
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    Beocord 7000 - Cassette Deck ?
    I am looking for information regarding the casettedeck in Beocord 7000 / 4941.
    I have a product with a defect cassettedeck and are looking for a donor (the cabinet is in exelent mint condition).
    Does anyone know if the cassettedeck is the same in Beocord 6500 or Beocord 6000 ???
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
  • 10-16-2007 10:07 AM In reply to
    Re: Beocord 7000 - Cassette Deck ?
    The 5500, 6500 and 7000 are all essentially the same deck. I am unaware of any major changes and I believe they all use the same service manual.
  • 10-16-2007 10:14 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Two different tapedecks were used during production. I don't know if they are interchangable.
    I have beocord 6500 in excellent shape and was thinking of letting it go.
    Last time I've used it - about 2 years ago.
    However I'm located in US and shipping can get very expensive
    David the BeoPerson
  • 10-16-2007 10:28 AM In reply to
    Dillen:
    I have a suspicion that if all you are doing is changing the cases, it won't make a lot of difference! Isn't it actually the same deck as in the 9500 - there were two types used there as well.
  • 10-16-2007 10:36 AM In reply to
    Of course the best thing to do is to re-skin a Beocord 5000 which has a much better tape deck! Proper VU meters and a non auto reverse deck. In some people's minds, the best cassette deck made by B&O. (Bit of controversy designed to annoy any 9000 owners!)
    There are two Beocord 7000s on Ebay at present going for the usual laughably small amounts!
  • 10-16-2007 12:12 PM In reply to
    • Dillen
    • Posts 5,008
    Beocord 6000 is all different, more like the 8000.
    Similar types of decks are used in Beocord 5500, 6500 and 7000 (and some Beocenters etc.).
    The cabinets are the same but I'm not sure about the general electronics.
    I've repaired many but never had to interchange decks.
    I agree with Peter on the 5000 though.
  • 10-16-2007 1:36 PM In reply to
    The cabinet of 6500/7000 is identical, also inside the deck. But not the 5500, it's completely different, inside and outside.
    All drives are different, 5500, 6500 and 7000 are NOT identical. 6500 and 7000 look quite the same... but it is not the same. The board on the drive ist different and the cable connector is different (180 degree mirror). If you try to connect a 6500 in a 7000 you will have a firework... or you exchange the drive and the cable!
  • 10-16-2007 3:15 PM In reply to
    • Dillen
    • Posts 5,008
    Great info !
    I won't ask you how you know about the fireworks  Laughing
  • 10-16-2007 3:41 PM In reply to
    • classic
    • Posts 224
    Re: Beocord 7000 - Cassette Deck ? ---- Tks very - very much !
    Dear all,
    I am truely impressed and very thankfull.
    Within a few hours I got 7 replyes and I now know in details how I can search to get a solution. I even have an offer - and I do agree the transport to Denmark is perhaps a little to high at this point of time, because I will start to search here local first.
    /Frede
    Filed under:
  • 10-16-2007 3:44 PM In reply to
    • Dillen
    • Posts 5,008
    I'm curious, what's wrong with the deck you have ?
