Latest post 10-17-2007 1:40 AM by Peter. 10 replies.
Page 1 of 1 (11 items)
  • 10-16-2007 9:25 AM
    Having to press GO before every command in Beo4
    Hi all, I have a bit of a problem (or is it?) with my Beo4.. when watching DVD, if I want to skip to the next chapter, then I have to press GO and then ^. If I want to scan, I have to press GO then >>. However, on my friends Beo4, he doesn't need to press GO. He only need to press ^ or >>. Does anyone know if there's anything I've set up incorrectly?
    Thanks!
  • 10-16-2007 9:26 AM In reply to
    Re: Having to press GO before every command in Beo4
    What is your set up - which TV and DVD?
  • 10-16-2007 9:53 AM In reply to
    Sorry I should have supplied that info in the first place. I have a Beocenter2 with non-B&O TV. I've set up the Beo4 as VIDEO 4 AUDIO 2.
    Thanks!
  • 10-16-2007 10:11 AM In reply to
    I had a sneaking suspicion it wouldn't be simple! Laughing I'll have to look that one up tonight if no-one else knows! Why Video option 4?
  • 10-16-2007 10:31 AM In reply to
    I'm afraid only the latest DVD players in the B&O range (that is, as from BV7-40) are making it possible to step through DVD chapters by a simple pressure on the arrows. Before that, you needed to press GO, then the arrow (BeoCenter 1, DVD1, BV7-32 etc). On the contrary, when playing a CD audio, only one direct pressure on the up or down arrows skips through tracks!
    It would be so great if all B&O DVD players spoke the same language, hopefully the forthcoming products are more logical & user-friendly than the first ones..
    Reunion Island is greeting you!
  • 10-16-2007 10:32 AM In reply to
    No particular reason. I'm not sure how to set it up. There's Config and there's also Option - what's the difference between them?
  • 10-16-2007 10:40 AM In reply to
    I'll play with mine tonight! An early BC2. I have a feeling Chris is correct though. Of course a Beo5 would be able to get around this! Laughing
  • 10-16-2007 10:41 AM In reply to
    Oh that might explain it Chrisreunion. My Beocenter2 is an older one without DAB, and my friend just recently bought his brand new, so B&O might have changed this in the firmware. Can anybody please confirm that?
    I was just astonished that I could skip chapters just pressing the arrows on his remote.
  • 10-16-2007 10:47 AM In reply to
    Thanks Peter. Would love to hear how you go with yours!
  • 10-16-2007 11:06 AM In reply to
    Oh yeah, one other thing. Is it possible to slow-forward (rather than fast-forward) with the Beo4?
  • 10-17-2007 1:40 AM In reply to
    Tried mine - a little odd as it is actually registered as V.Tape 2. But it needs the Go button first.
