Latest post 10-16-2007 11:05 AM by Beobird. 7 replies.
Page 1 of 1 (8 items)
  • 10-16-2007 6:01 AM
    • Beobird
    • Top 150 Contributor
    • Joined on 04-19-2007
    • Netherlands
    • Posts 506
    • Gold Member
    Beovision 6-22 for the pc ?
    Beoworlders,
    I'm currently a owner of a AG Neovo E-17 lcd, but I felt in love with the design of the 6. The problem is that I don't know if this is a good choice for the pc, because of the  screen reaction and the resolution (or are there mkII mkII types ?). So my question is if there is someone on this forum who uses the 6-22 or maybe even the BC 6-23 for the pc ?
    We Can't Get Enough B&O Stuff...
  • 10-16-2007 6:58 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Beovision 6-22 for the pc ?
    It's fine if you can live with the screen resolution. A vertical resolution of 768 pixels is worse than that of the MacBook 13" consumer-based laptop. If you're planning on using an LCD for work, then you probably would need something with a better vertical resolution.
    The Apple 20" LCD is dirt cheap these days. Even the 23" is affordable.
  • 10-16-2007 7:46 AM In reply to
    • Beobird
    • Netherlands
    • Posts 506
    • Gold Member
    I use my pc for video's and sometimes games so I quess 768 pixels isn't that good Sad. I probably will buy the Neovo E-22, or I will smash the display out of the Beovision 6 and put another in it Big Smile. Actually I hope B&O will release a MKII model, because I really love the design
    The Neovo P-19 looks cool too but it hasn't got the charme of the Beovision
  • 10-16-2007 8:35 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    I would buy a mac LCD monitor. So much cheaper and SO much more appropriate.
  • 10-16-2007 9:03 AM In reply to
    I agree with the others who have provided feedback. Clearly, the Beocentre 6 is out of the question on price alone.
    Many B&O dealers use the Beovision 6-22 for their own PC needs, but I would not..
    Regards Keith....
  • 10-16-2007 10:34 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    £399 is a lot to pay for a 20" monitor with, it has to be said, decidedly average specifications. It may look nice but then so does the BV6 - the argument there was that the BV6 is expensive and the specs aren't as good as they could be. You can certainly pick a better panel than the Apple it depends how much you value the look.
  • 10-16-2007 10:53 AM In reply to
    • Ruivar
    • Not Ranked
    • Joined on 07-12-2007
    • Denmark
    • Posts 72
    If the price doesn't matter to you, I would definately go for the BeoVision 6. I can highly recommend it!
    Ruivar
  • 10-16-2007 11:05 AM In reply to
    • Beobird
    • Netherlands
    • Posts 506
    • Gold Member
    In a certain way the price does matter to me. I'm now searching in a pc monitor class <1000 with really good specs, but the looks of the Bv6 is for me worth the double if the specs would be the same as a screen below 1000,- euro's, and I quess (if I see the replies) that it is not Sad.
