Latest post 03-20-2008 7:53 PM by StUrrock. 60 replies.
Page 1 of 3 (61 items) 1 2 3 Next >
  • 10-14-2007 5:14 PM
    DVDPEDIA
    No, not a disease or a deviation. Instead an incredibly efficient way of cataloguing and retrieving your DVDs stored on harddisk. Must say - I was getting a demo of Kaleidescape the other day and wondering whether that was the way to go. (Very expensive way to go.) And then I came across DVDpedia -- which costs a lot less. You do need storage, but I have a 3 terabyte server at home, and this program in my MacMini seems to be doing the trick. Now I'll just have to transfer my DVDs, will take some time.
    Very intuitive and elegant interface:
    http://bruji.com/dvdpedia/
  • 10-15-2007 10:31 AM In reply to
    Re: DVDPEDIA
    Thanks for the link.
    I was interested in Kaleidescape
    but for my taste is was too expensive.
  • 10-15-2007 1:52 PM In reply to
    Re: DVDPEDIA
    Coolskin:
    Yes, I do believe you'll get a Kaleidescape feel to the interaction, plus more information if you want it, as DVDPedia goes on the net an retrieves fact sheets, stills, info on actors, behind the scenes, etc. Have just begun trying it out (at USD18 it's a couple of pints where I live). Will report.
  • 10-16-2007 7:55 AM In reply to
    Re: DVDPEDIA
    soundproof:
    Coolskin:
    I can't wait to try this one out.
    I have added five dvd covers and inserted one original DVD in my PowerBook.
    In the fullscreen mode there is a PLAY button, but I can't find a way to play the uncompressed full DVD now stored on harddrive.
    It seems I need some ripping software to extract the movie + audio (dolby?) to the harddrive.
    If you have some more detailed info how you handle DVDPedia and stored DVD content please let us know.
    When it can do what I think it can, I will buy 1 terabyte harddrive and place it central in our home for DVD and backup storage.
    Filed under:
  • 10-16-2007 9:12 AM In reply to
    Re: DVDPEDIA
    This is how I first came across this, from March 7th of this year:
    http://www.htguys.com/archive/2007/March09.html
    It's subsequently been updated, actually answering to a few of the suggestions from the HTguys.
    http://www.htguys.com/archive/2007/October16.html
    That's when I got really interested.
    You need to rip your DVDs to the harddisk. For that you'll find various applications you can use. Handbrake is used by some, I use Mactheripper.
    http://handbrake.m0k.org/
    http://www.mactheripper.org/
    When extracting films, I recommend you pick the option to extract the feature only. (That is, not the extras, or the trailers in front, etc.) That way, when you pick a cover the program will go immediately into the feature, without warnings, trailers and menu.
    Also make certain you set the program to extract all the audio information, to ensure you get the best possible signal for your setup. And do listen to the HTguys' podcasts. In both it takes a while before they get to talking about DVDpedia, but they give you a good overview.
  • 10-16-2007 11:45 AM In reply to
    Re: DVDPEDIA
    I've actually replied to this hours ago, but it went to moderation for some mysterious reason. (Very persnickety feature of BeoWorld, by the way).
    DVDPedia will most likely put Kaleidescape out of business. It's remarkably superbly excellent.
    You have to rip your DVDs to your harddisk using Mactheripper or Handbrake. I prefer Mactheripper.
    You can opt to not rip the entire DVD, skipping intro's, etc.
    Once the DVD is on your harddisk you're set. Add a movie through DVDPeida (I like to add them from IMDB, which has very good synopses and crew and cast information).
    You need to have the info-pane open. (That's the window below the coverview that shows details of the movie.)
    Now just drag your DVD's TS-file from where it is on your harddisk to the info-window, and let go of the mouse-button. You have now linked the listing with your movie file.
    When you're looking at movies, in full-view (with all covers), you'll find a large white PLAY button that you can click when you have selected a movie, or you can use the play-button in the menu if you're in window-mode. This will launch DVD-player.
    There are ways of setting DVDPedia to have it use VLC or another player. I prefer VLC, because the colour management and sound management is better in VLC, in my opinion.
  • 10-16-2007 3:59 PM In reply to
    Re: DVDPEDIA
    soundproof:
    Thanks for the info on the ripping software. Tried Mac-the-ripper on "i'robot" and works o.k. for me. My PowerBook is not suitable for storage of movies so to speek. So I will buy a (much) bigger separat harddisk to store most of my favorit DVD's.
    Hope my Mac Mini (first edition) which is hardwired to the BV7 can handle streaming video from a seperate harddrive. Will check this before I will run of to the store...
    Yet again thanks for sharing this usefull DVDPedia (18 bucks) and MacTheRipper (free) software.
  • 10-16-2007 5:37 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Re: DVDPEDIA
    Wow, that looks very cool!
    I was planning to create a filemaker database with my DVDs, as I used to have one on PC in access format, but this looks way better. I will try it out! Thanks for the link!
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 10-17-2007 9:55 AM In reply to
    Re: DVDPEDIA
    Both programs are now on the Mac Mini.
    Have copied "Batman begins" to the harddrive and started DVDPedia in fullscreen mode to start the movie on the linked BV7.
    No glips, hickups or what so ever.
    Even the 5 speakers are on. Got the impression Dolby 5.1 is active.
    But that seems a little od, because only a simple headphone jacket connection comes from the Mac Mini.
    Happy me :)
  • 10-17-2007 11:20 AM In reply to
    Re: DVDPEDIA
    This may be down to how you have set your television (BV7?) to handle the signal. I doubt that it processes 5.1 from the analog signal coming out of the Mac Mini. (However, you can get surround out from the Mac Mini).
    Yesterday I was streaming movies to the iMac a block away from the server, showing movies without a glitch over wireless. But I have found out that the graphics card in the Mac Mini is having a little trouble processing Wi-Fi without little skips in the signal -- will look into this and post a solution. (May actually have to run an Ethernet cable from the server to the Mac Mini). Works flawlessly over wireless on the iMac, though.
  • 10-17-2007 12:26 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    Re: DVDPEDIA
    downloaded CDpedia and DVDpedia. Excellent and easy to use!
  • 10-17-2007 1:51 PM In reply to
    Re: DVDPEDIA
    I'm quite blown away, I have been programming my iPod Touch to control iTunes and DVD-Pedia, etc., using Remote Buddy. Wireless, two way, can pick speaker pairs (through connected Airport Express units), control playback, find music ...
    This is the Touch display (one of various - there's another very pretty one with the whole cover on the display, you can have playlists) - and you interact with finger presses.
  • 10-19-2007 8:46 AM In reply to
    Re: DVDPEDIA
    Have placed several orders:
    - iomega 750gb minimac storage from AppleStore.nl
    - DVDPedia registration
    Next monday I can start uploading...
    I think i will not buy the iPod touch this year.
    The solid state memory is somewhat low. When it's approx. 32gb I will reconsidder.
    Very nice interface though.
  • 10-19-2007 2:54 PM In reply to
    Re: DVDPEDIA
    soundproof:
    Turns out my Mac mini was sick - the network card was bad. Got a replacement unit today, hooked it up - presto! Now it's receiving streamed  movies from my stand alone server through DVDPedia as smoothly as if I had placed a DVD inside it!
  • 10-19-2007 10:01 PM In reply to
    Re: DVDPEDIA
    How is the Ipod toch working as a remote. Will it show the cover of teh moview with DVD pedia?
    is it cumbersome to start remote buddy, will it autostart. How long does it take after power on until it is connected to the mac?
    Is it a decent 2 way remote or just a toy leaving you to want more. I have the Imac & BEO4 solution but would consider mini mac, infrant NAS and ipod touch for  christmas.
  • 10-22-2007 2:07 PM In reply to
    Re: DVDPEDIA
    Any idea how to avoid auto start up of the DVD player when inserting a DVD disk?
    The minimac from Iomega is sitting next to the PowerBook G4 and connected through USB 2.0
    I'm uploading most of my DVD's to this 750gb harddrive with the help of the (little bit) faster PowerBook G4 12" ;-)
    At least this way it's more convinient, cause the laptop is my daily computer.
    The Mac Mini is stored away and hardwired to the BV7.
    The DVDPedia software is on both the PowerBook and the Mac Mini.
    I'll now know that with an export of my collection library the same "links" can be made active on the Mac Mini.
  • 10-23-2007 4:26 AM In reply to
    Re: DVDPEDIA
    The iomega 750gb harddrive isn't as quiet as I was hoping. (Twice as noisy as the Mac Mini)
    I've tried several locations; in the cabinet under the Mac Mini, under the couch.
    Unfortunately the fans pick up speed when cooling is necessary, and then they are noticable.
    I will upload the movies anyway.
    My next option is to store the iomega harddrive next to my DSL modem, in a closet central in our home.
    Possibly with the aid of an AirPort Extreme Base Station?
    apple.com
    Share your hard drive
    Now you can share an external USB hard drive over your wireless and wired network by simply connecting it to the USB port on your AirPort Extreme Base Station. Called AirPort Disk, it's perfect for sharing files, making backups, and more. You can even connect multiple drives and printers using a USB hub (sold separately). And it works with both Mac and Windows. (See system requirements.)
  • 10-23-2007 5:33 AM In reply to
    Re: DVDPEDIA
    IN SYSTEM PREFERENCES>CDs&DVDs>Pick the behaviour you want, in this case that the DVD should not be opened automatically.
  • 10-23-2007 5:34 AM In reply to
    Re: DVDPEDIA
    Coolskin:
    This is what I'm doing, in order to get the server out of the way - both to cut down on noise but also to keep it safe. You can then either connect wirelessly, or run an ethernet cable from your Airport Extreme to your MacMini, in order to have the highest possible transfer speed. Works nicely on my setup.
    ADDING: There's an Ethernet connection from my server to my Airport Extreme Base Station, and I'm also running an Ethernet cable from the Base Station to my MacMini. It turns out I get a much more reliable playback of DVD quality files over cable than over wireless.
    Wireless works perfectly to my new iMac -- but I prefer the cable to be certain of not getting a playback hick-up to the MacMini.
  • 10-24-2007 4:20 AM In reply to
    Re: DVDPEDIA
    Now the video playback is sorted out.
    i would like to go one step further.
    Audio:
    I think the Mac Mini headphone socket also has a light emitting output. Digital?
    That raises two questions:
    1. Is it possible, how, and at what cost to connect a cable to the Mac Mini to upload Surround/Dolby Digital 5.1/DTS sound into the BV7.
    2. What setting, and connection, do I need for the BV7 - model dec. 2004.
  • 10-24-2007 5:31 AM In reply to
    Re: DVDPEDIA
    Have a look at this. I don't have a BV7, and haven't tried it to that -- but seem to remember that someone here had trouble with converting the optical toslink signal from a mac, think that may have been due to the converter, though.
    http://forum.beoworld.org/forums/post/22596.aspx
  • 10-26-2007 3:55 AM In reply to
    Re: DVDPEDIA
    Bummmmmmer. My (old) Mac Mini has no digital audio output. I assumed it had, because the new model does. After checking the rear there was no light emitting from the audio output. And "About this Mac" showed me no info at Firbre Channel.
    When I bought the non-Intel Mac Mini my intention was to make it a MEDIACENTER. I realized it could become a long term plan. The Beoport makes it possible to listen to N.Radio and N.Music. And now with the software DVDPedia I have added video to my "mediacenter". I'm more then happy for the moment. But... next stage in completion would be:
    - DVD audio from Mac Mini to BV7 including surround sound. This will most probably mean I have to buy an (additional) Intel-core duo Mac Mini
    - Operate DVDPedia fullscreen with Apple Remote. On the (non-Intel) Mac Mini I have to add an IR reciever to make this happen.
    - Operate DVDPedia fullscreen with BEO4. This will most likely be done by Lintronic, don't you think?
  • 10-26-2007 4:23 AM In reply to
    Re: DVDPEDIA
    The price we pay for being early adopters - I've also at times ended up with hardware that can't do very obvious stuff.
    You can get the surround out of your macmini by using a soundcard connected via firewire or usb -- but then you might also want to consider upgrading to the most recent macmini. It's faster and has IR, wireless and bluetooth. I've connected it directly to my tv using a dvi to hdmi cable.
    Once I have everything playing as I want, I will be moving control to a Beo4. However, I understand that Lintronic requires Windoze. I will be looking at iTrans/iRed, Mac software which supplies Beo4 emulations to IR transmitters. You can control all kinds of hardware, B&O and non-B&O.
    I'm waiting for their iRed 2.0 which is supposed to be iPod Touch compatible, as well. If I can put a Beo4 emulation on the Touch, then I can control B&O and non-B&O, as well as Apple software, from one unit.
  • 10-26-2007 4:16 PM In reply to
    Re: DVDPEDIA
    I ran into a snag in the mad master plan.  My TV is only 1080i so the picture from my mini is terrible.  I can't get it to scale, blah blah blah.  Well the good news is I've worked around that.  I ripped a DVD into an mp4 file for Apple TV.  This works like a champ.
    However, I suppose DVDPedia doesn't launch mp4 files, does it?  Only the Video_TS stuff?
    edit: it just occured to me that even if it did launch the file, it's still on my Mini.  Curses!  And after I found a 1tb fanless HD option for 211 euros =(
  • 10-26-2007 4:23 PM In reply to
    Re: DVDPEDIA
    dilznik:
    Try out DVDPedia more...
    I have read that you can link everything. Select the file and drop it to links ("koppeling" in Dutch).
    Link entries to URLs, files, images, Video_TS folders or other entries
