Latest post 04-23-2007 12:38 AM by Kevin. 5 replies.
Page 1 of 1 (6 items)
  • 04-20-2007 1:26 PM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Speaker wiring diagram
    does anyone have the wiring diagram for Beolab 4000 type speaker or any of the Mk1 powerlink cable speakers?
    Thanks in advance,
    Kevin
  • 04-20-2007 1:58 PM In reply to
    Re: Speaker wiring diagram
    Put the service manual for the Beolab 4000 speaker on site - Mk2 I am afraid!
  • 04-21-2007 2:42 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Many thanks PeterYesCool
  • 04-22-2007 7:12 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Unfortunately this manual is of the era where you change the pcb and the wiring diagram is little more the the block diagram.
    What I'm most interested in is what B&O do with the input signal. The speaker can take powerlink and  line. From the manual I am assuming they pre amp the powerlink signal to line level. This is the part of the circuit I'm most interested in. They seem to use the LF353 as pre amp on the older gear.
    Any help on the diagram would be much appreciated as would any comments on simple chip based pre amps.
    Thanks,
    Kevin
  • 04-22-2007 5:18 PM In reply to
    Kevin,
    I think the following is what you are looking for:-
    Circuit diagram
    Regards Keith....
  • 04-23-2007 12:38 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    YesThanks KeithCool
