Latest post 10-14-2007 5:44 AM by Sebastien. 6 replies.
Page 1 of 1 (7 items)
  • 10-14-2007 4:28 AM
    PowerLink ans MasterLink cables
    anybody can list the best manufacturers for the PowerLink and MasterLink cables?
    S.F
  • 10-14-2007 4:45 AM In reply to
    Re: PowerLink ans MasterLink cables
    Bang & Olufsen?
  • 10-14-2007 4:48 AM In reply to
    Anybody has tried other than B&O cables?
  • 10-14-2007 5:10 AM In reply to
    I have tried and supplied Boscomm powerlinks and they seem fine.
    Regards Graham
  • 10-14-2007 5:12 AM In reply to
    Thanks Graham,
    do have the link to their website?
    S.F
  • 10-14-2007 5:30 AM In reply to
    SF...you can run your ML with simple CAT 6 STP cable....this tip comes from our resident Marcus who has done this..and he's provided  a wiring diagram....search it..
    We are trying the Powerlink over CAT 6 STP now...and will report back on how that works...but Lexicon(M) does it...with powerlink...so that's postiive...
    Basically, cut your ML cable in half attach RG45 (shielded) ends on both sides...and run the STP in the walls....
  • 10-14-2007 5:44 AM In reply to
    Thanks Frank.
    So that should be an alternative to the Lexcom cables. isn't it?
    Sebastien Fray
