How feasible would it be to make the following mod to a BC9000
Remove the tape carrier, replace with the ipod dock from "say" the Phillips portable dvd player, or maybe something similar fabricated out of aluminium. Wire it up with the ridex cable etc so that the ipod charges, plays and is controlled by your B&O remote. To take it to the limit, use the cables and chips from the DLO ipod dock so you can also navigate through your ipod on your TV.
What do you think guy’s?
Don’t think it would be easy, but is it feasible?
