Latest post 10-11-2007 5:53 PM by Tom. 8 replies.
Page 1 of 1 (9 items)
  • 10-11-2007 11:04 AM
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    remove the fabric of a BL6000
     Hello
    How is fixed the fabric of a beolab 6000 to the frame ?
    It's possible to change it ?
     thank you
    DU BEAU, DU BON, DU BO.
  • 10-11-2007 11:08 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: remove the fabric of a BL6000
    Just slide it off.
    Roger
  • 10-11-2007 11:18 AM In reply to
    Slide it upwards and then forwards.  Be careful though since some of the clips are plastic.
  • 10-11-2007 12:44 PM In reply to
    • archie
    • Paris
    • Posts 497
    Ok,
    But if i want change only the fabric ?
  • 10-11-2007 12:54 PM In reply to
    Hello archie.
     The best idea would be to contact your local Bang & Olufsen Retailer and let him change the fabric cover.
    If you really want to do it yourself you should look at the fabric cover from the back. There are little "hinches" where the fabric is being hold in place and under tension. Pull or cut it out of there and it should come loose.
     But to be honest, I can not give you a better answer.
     Regards
    Alex
  • 10-11-2007 2:36 PM In reply to
    • Sal
    • Top 200 Contributor
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    I know the fabric on the BL8000s is hooked on and can be removed with some skill. But I believe the top and bottom of the fabric on the BL6000 grille are glued in place, and would require a professional's help.
    What would you like to do with the fabric? And would it be easier to buy new different color grills if you want to change the color alone?
    -Sal
    Love B&O, but no longer addicted.
  • 10-11-2007 3:09 PM In reply to
    • archie
    • Paris
    • Posts 497
    hello
    I want only change the color.
    but i dont no if it's possible to buy new at BO
  • 10-11-2007 3:18 PM In reply to
    Your dealer can supply new frets in a range of colours.
    Regards Graham
  • 10-11-2007 5:53 PM In reply to
    • Tom
    • Top 25 Contributor
    • Luxembourg
    • Posts 3,175
    archie:
    hello
    Most dealers have them on stock, you just have to ask. They are not that expensive.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
