After adding two more link rooms with TV's I have hum in the system :-(
So my first guess was this could be related to ground loops from aerial connection on the one hand and ML connection on the other. As ML is a differential (is this the correct word?) bus I was wondering what the ground connection is for?
Do you also experience such problems and how did you solve them? Could it be a solution to cut the ML ground connection and use the aerial ground instead? A ground isolator in the aerial is not possible as I have a satellite system and need the DC connection for signalling purposes.
Many thanks,
Marcus
