Latest post 10-14-2007 7:02 AM by kallasr. 5 replies.
Page 1 of 1 (6 items)
  • 10-08-2007 5:10 PM
    BeoLink Passive
    could you pls tell me which non B&O speakers can be connected to the BeoLink passive? ( Power? Impedance?)
    S.F
  • 10-08-2007 6:11 PM In reply to
    Re: BeoLink Passive
    The passive is a reasonable general purpose amp rated at around 30wpc into 8 ohms (Depends on how you measure?) so most speakers capable of handling this sort of power will be OK.
    I have a passive which is quite happy with a pair of S80's but I often use it with CX50 as an alternative.
    Regards Graham
  • 10-11-2007 11:15 AM In reply to
    Re: BeoLink Passive
    Thanks.
    What are the manufacturers of the S80 and CX50?
    S.F
  • 10-11-2007 11:48 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: BeoLink Passive
    B&O!
    I got some Wharfedale 8 Series hooked to my beolink passive. That works.
    Best regards
    Ralf
    PS: maybe you should google for ohm and see what a difference it makes.
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-14-2007 4:22 AM In reply to
    Re: BeoLink Passive
    Thanks Ralf.
    Are u happy with the Wharfedale speakers?
    Do you mean "Diamond 8" by the 8 series?
    S.F
  • 10-14-2007 7:02 AM In reply to
    • kallasr
    • Posts 1,077
    Re: BeoLink Passive
    Yes Diamond 8 Series, and I am happy with them. It's just for easy listening in the dining room.
    Ralf
