Latest post 10-09-2007 10:22 AM by Frank Rizzo. 14 replies.
Page 1 of 1 (15 items)
  • 10-08-2007 4:44 PM
    Mutiple ML distribution boxes.... Quick if possible...
     I'm in the middle of the install now.......so a quick answer please.....sorry for the rush...
    If i've got say 6 passives....can I run 1 ML distribution box for the downstairs....and then run 1 of the connections to a ML distribution box upstairs......??????
  • 10-08-2007 4:53 PM In reply to
    Re: Mutiple ML distribution boxes.... Quick if possible...
    Yes that is possible
    So for instance:
    Radio ------ TV (master) (between radio and TV split cable in the middle)
    ML Juction downstairs ------ one cable from junctionbox downstairs to junctionbox upstairs
    Wanna play?!! (Also a PRIZEWINNER ON BEOWORLD!)
  • 10-08-2007 4:54 PM In reply to
    Shouldn't be a problem and infinitely preferable to what your multiple ML junctions would otherwise look like. Wish more people used those five-way distribution boxes more!
     Nick
    Nick
  • 10-08-2007 5:20 PM In reply to
    Awsome...thanks for the help....and quick......
    Just to be clear...the ML distribution box has the Audio IN and then 4 link slots...so...
     I'd use 1 of those 4 to run upstairs to the AUDIO IN of the ML distribution box upstairs....
    then.....i'd have 4 links available upstairs...yes??
    thanks again guys...K
  • 10-08-2007 5:34 PM In reply to
    Sorry Frank, i was confused. Look at this link
    http://forum.beoworld.org/forums/post/34492.aspx
    You should have 5 left upstairs...
  • 10-08-2007 5:35 PM In reply to
    Embarrassed
  • 10-08-2007 5:44 PM In reply to
    Hi Chucky....on my ML distribution box.... 1 says Audio Link..., 2 says Video link..., then it says ML link 1 thru 4.......
     How does that all work??? thanks, k...
  • 10-08-2007 5:52 PM In reply to
    Ok this is my setup
    BS 3000 in audiolink
    BV7 in videolink
    This is important because I think this should be paralel
    Then you can use the rest for link audio. If you want to setup another TV You need to run a coax as well from your master TV.
  • 10-08-2007 5:56 PM In reply to
    • Sal
    • Top 200 Contributor
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    The labels on the ports on the ML distribution box, apparently, are for aid only, and don't meal a thing regarding the kind of connection you're going to link to... I say apparently, because (maybe it was my setup), but the LINK 1, etc ports really acted like Links when I wanted to merely extend a ML cable's length in an ML experiment in my living room. Hopefully your results will vary.
    -Sal
    Love B&O, but no longer addicted.
  • 10-08-2007 6:03 PM In reply to
    Big SmileSal you are right, but i thought that the audio and master should be connected together and the ML cable should be split in the middle
    So Audio    ----------------- Beovision
                           I
                           I
     Rest of ML distribution
    This should help
    http://www.beoworld.org/beotech/options1.htm
    Look for other options on
    http/www.beotech.co /UK
  • 10-08-2007 8:30 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Frank;
    Use any of the slots for your M-L cable connections.
    They all work fine for our multi-room system.
  • 10-08-2007 11:59 PM In reply to
    Hi Swiss...Thanks !! very important question......
    So..(in the ML distribution box).. I can connect the master Audio in the Audio slot and then say 5 passives in the remaining  5 slots??????
     Thanks again guys !!
  • 10-09-2007 4:06 AM In reply to
    No matter what type of distribution boxes you decide to use, all connections are in parallel meaning you can daisy-chain the connections from room to room or connect all ML cables at a single point or a mixture of both.
    It does not matter what products are connected to an Masterlink Cable (Master/Slave) they all get connected in parallel.
    Regards Keith....
  • 10-09-2007 4:29 AM In reply to
    The ML is very flexible, every plug is identical on the whole network.
    You can connect it in any way and it will work. You can also do any network shape, bus, star...
    Also you can move the master from a room to another, plug it and it will still work.
    p.
  • 10-09-2007 10:22 AM In reply to
    Thanks guys...!!!
     Got it.......
