1st March February 2012
Latest post 10-24-2007 4:50 AM by kawo. 52 replies.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Tom
- Joined on 04-16-2007
- Luxembourg
- Posts 3,175
Alex: tom: Alex: tom:
if the weight will increase according to the screen size, this TV will have around 250 kg. WOW!
Actually it's around 500 kg...
how come you know???
I could tell you, but then you'd mysteriously go missing and never be seen again.
Ok, I won't ask again!
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
The Beonic Man
- Bath
- Posts 426
The thought of something 112 inches big that rises is a scary one! Can't wait for that one!!
"We can rebuild him. We have the technology."
7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
The Beonic Man
- Bath
- Posts 426
jandyt:I often have this problem
Well don't stand so close to him next time Andy!
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
GANGO: the BV 10 will not be mounted on the wall......it will BE the wall !!!
Actually, no... it will rather be part of the floor  Roger
The Beonic Man
- Bath
- Posts 426
BV 10 ... Bigger Version (by) 10x !! Really looking forward to seeing this innovation! Simon.
Tom
- Luxembourg
- Posts 3,175
The Beonic Man:BV 10 ... Bigger Version (by) 10x !! Really looking forward to seeing this innovation! Simon.
It is not yet sure if it will be built or not. What the dealers have seen is only a product study.
The Beonic Man
- Bath
- Posts 426
£85,000? Are you sure you have got that right? If that's true then that is a very small market they are aiming for. Simon.
Tom
- Luxembourg
- Posts 3,175
The Stig - ver. 1.4:BV10 is 103"- 500 kg and will be around £85.000 start saving
iirc, and I think I do, I was told 132".
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
The Beonic Man: £85,000? Are you sure you have got that right? If that's true then that is a very small market they are aiming for. Simon.
Yes think it's the oil market thy are going for...
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
Roger: GANGO: the BV 10 will not be mounted on the wall......it will BE the wall !!!
It will be part of the floor below if you haven't got strong floorboards!
Lee
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
Dealer Info:
New B&O tv, 103 inch, florstand with tilt and turn function(like the BV7-40, just way bigger), 500 kg. Simple design, looks like bv4. The Tv can move up and down the stand, when turned off it will be down, and then slide up when turned on and the centerspeaker will slide forward. No wall option. Price, approximatly 112.000 €.
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
Beovision 10, The mother of all TV's.
aweicc
- Joined on 06-21-2007
- Posts 105
Well, atleast you can be sure that no one is going to break into your house and steal your tv...
Daniel
- Svinarp, Sweden
- Posts 1,284
Good news! Then SHMBO will think the BV9 look small and cheap.
