Hello community,
does anyone know the voltage-levels of the datalink signal, as it is on the scart-jack of an avant 28 ??
thank you for your support
Jottem
Jottem,
Not sure which signals you are referring to when you say "datalink signal" on the SCART socket, if you mean the one way AVL on pin 8 which is also used to define automatic format it is as follows:-
Inactive Source 0V to 2Volts4:3 format 9.5v to 12 volts16:9 format 4.5 volts to 7 volts
If you are not talking about pin 8 of the SCART, please define which signal you are talking about.
Regards Keith....
I'm also looking for specs for the AVL signal (the one that controls a VCR or DVD via the SCART socket).
Can anybody help?
Regards Rasmus
Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
Hi Keith,
Yes, I mean Pin 8; so what is the level for high and low ??
thanks for your help.
jottem
If you put an scope on pin 8 you will see the actual "data" stream normally from a Beo4 command sitting above the voltage depending on what format has been set with a peak-to-peak value of about 1 volt.
So, if the format is currently set to 16:9 then there will be a constant voltage level between 4.5 and 7 volts and it normally it sits around 6 volts but varies by many factors including cable length. On top of the six volts will be the "data" stream. So in this example with the format voltage at 6 volts then the data stream will be between 6 & 7 volts.
