Latest post 10-08-2007 12:29 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 10-08-2007 8:00 AM
    BV9-can it be ISF calibrated?
    I understand that B & O calibrates the BV9 in the factory.
    Presumably,it is for this reason that the User Adjustments are confined to the usual parameters-brightness,contrast,colour etc.
    I was wondering if the BV9 can be ISF calibrated.
    If so,has anyone carried it out?
    How accurate is the factory calibration?
  • 10-08-2007 8:44 AM In reply to
    Re: BV9-can it be ISF calibrated?
    I am sure it can be -there is a hidden service menu which allows further calibration. Whether this is a good idea is another matter.
  • 10-08-2007 10:41 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    Hi, I am thinking in the same direction, however not with a BV9, but with a BS3 and a connectec projector (JVC HD1) and a Panasonic Plasma. There are many parameters in the BS3, however with no detailed knowledge I would not change any value here. The colors and gamma is not perfect so far, I know that both HD1 and Plasma can perform much better.
    So the key would be to understand the values in the BS3 and display device.
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 10-08-2007 12:29 PM In reply to
    The service manual is on site but I would suggest a professional is needed to adjust the parameters.
