Latest post 11-05-2007 4:28 AM by francis. 9 replies.
Page 1 of 1 (10 items)
  • 10-08-2007 4:32 AM
    Beoport and Ouverture
    Can I integrate the Beoport in a integrated home system based with an Ouverture as main device?
  • 10-08-2007 4:40 AM In reply to
    Re: Beoport and Ouverture
    No... Beosound 3000 and 3200, 9000, 4, BC2,  are compatible.
    Some older 3000 and 9000 need to be adapted.
     p.
  • 10-08-2007 6:27 AM In reply to
    How does this fit with the title of the following posting:
    http://forum.beoworld.org/forums/thread/31537.aspx
    This reads as if a connection should be possible, maybe with some limtations?
  • 10-08-2007 12:23 PM In reply to
    • francis
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Münster, Germany
    • Posts 108
    It is definitely not possible to integrate an Ouverture and Beoport to a "normal" link system as the Ouverture does not support NMusik and NRadio. But there might be a workaround if you have a Mac. As the post in the mentioned link was written by me, I  post here a translation for your convinience.
    In such a setup (Mac+Ouverture+Beoport) it should be possible in principle to play N.Music. However not by means of Masterlink integration and Beoplayer, but using the Mac plus iTunes. I would connect the Mac to the AUX input of the Ouverture and control the Mac with BeoLink 1.5 software. To control the system you would however need an additional infrared eye connected with the Beoport. The Ouverture would then distribute the audio signals via Masterlink to the rest of your system and you could contro everything with a Beo4 (but not from linkrooms).
    To be honest, I never tried this configuration but I believe it should work.
    francis
    |BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
  • 10-08-2007 1:17 PM In reply to
    Dann kann ich ja wohl auf Deutsch schreiben.
     Sorry für die vielleicht dummen Fragen, aber ich habe die Anlage mit einem gerade gekauften Haus übernommen und versuche herauszufinden, wie ich die Vorteile des alten Systems ohne grundsätzlichen Neuaufbau so weit wie möglich nutzen kann.
    Die Ouvertüre ist über einen ML/MCL-Vonverter mit diversen passiven Speakern im Haus verbunden.
    Ich habe bereits einen Multimedia-Receiver (D-Link DSM-320), den ich über Aux für Audioanwendungen einbinden könnte. Auf die Weise könnte ich Musik vom PC im ganzen Haus hören. Kann man das dann irgenwie noch so einrichten, dass eine Fernbedienung des DSM-320 über die BEO4 möglich wäre?
  • 10-11-2007 7:07 AM In reply to
    • francis
    • Münster, Germany
    • Posts 108
    Zur Bedienung mit der Beo 4 fallen mir drei Möglichkeiten ein (die ich aber auch nur aus der Theorie und ohne eigene praktische Erfahrung kenne)
    1. Umrüsten des Reciever (Fachmann für sowas ist Ulf Kiener, auch hier im Forum sehr aktiv)
    2. Irtrans
    3. Lintronic
    Vielleicht bietet ja auch die neue Beo5 eine Möglichkeit, frag doch mal hier im Forum
  • 10-19-2007 6:46 AM In reply to
    Kann mann Beoport wohl an eine Beovision Avant anschliessen? An alle Modelle?
  • 10-19-2007 8:54 AM In reply to
    • Ulf
    • Top 100 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 665
    Wenn man den nötigen Audiomaster auch noch mit anschließt,
    dann schon.....
    Ulf
  • 11-04-2007 5:52 AM In reply to
    @Francis  Vielen Dank für deine Hinweise. Beide Systeme sind grundsätzlich geeignet und auch die grösste Logitech Harmony-Fernbedienung wäre wohl eine gute Option. Leider sind allerdings alle ohne Einbindung in das MCL-System im Haus, oder geht das irgendwie? Ich habe das aus den Unterlagen von Lintronic und IRTrans nicht herauslesen können.
  • 11-05-2007 4:28 AM In reply to
    • francis
    • Münster, Germany
    • Posts 108
    Ich bin leider auch kein "Link-Experte", schon gar nicht für die älteren Systeme. Vielleicht startest Du am besten noch einmal einen eigenen speziellen thread hierzu. Es gibt sicher eine ganze Reihe versierter Experten hier im Forum
    Gruß
    francis
