wtlc2zpx: In most cases, the TV will have transmitted all the channels to the recorder, so there is no need to tune. You may have a fine tune menu, but it is usually not useful.
p.
True- although I'm not sure from the original post if the V8000 is a new addition or if it has faulted and was previoulsy OK.
Two points - a bit simplistic, but its often the case that these are the overlooked causes of apparent faults.
Firstly, nowe the VCR is connected, try retuning the TV from scratch, as if new. The TV copying its channels to the VCR happens during set up, so if you have simply added a VCR - say from another room - then this "handshake" may not have occured, and trhe VCR may have tuning errors from a previous set up.
Secondly, a poor/damaged RF cable between TV and VCR could give these symptoms, if the grainy channels are weaker than others, and cannot get enough signal into the VCR's tuner.
Or it could be faulty, as its unusual to get two tuners ( TV and VCR ) getting different results in the same room, with the same incoming signal.
good luck.
Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
