Latest post 10-05-2007 7:17 PM by symmes. 1 replies.
Page 1 of 1 (2 items)
  • 10-05-2007 4:50 PM
    Beosytem 1 and panasonic tv
    Does anyone know how to access panasonic service menu to adjust picture geomotery. I have the 58 inch 600u with vga cable hooked up between Beosystem 1 and the tv- it throws a really nice picture back i get balck bars on the left and right side that i am sure that i can get ridd off via the panasonic service menu.
  • 10-05-2007 7:17 PM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Re: Beosytem 1 and panasonic tv
    Tell us the rest of your set up.  If you are using a cable box similar to the one in my region, Cox, you change the picture format via cable.
    Ray
