Any one had any luck using a beosystem 1 with Apple TV and using your Beo remote. Do you need to use Lintronic to control or is there a work around?
B&O has yet to release the new update for the BS1 that would allow it to work with the Apple TV, via Beo4. They are working on it, so they say ;) The BS3 already has the codes for it.
Joe
