Latest post 10-05-2007 2:57 PM by olegbang. 2 replies.
Page 1 of 1 (3 items)
  • 10-04-2007 5:35 PM
    Beolink Passive and Beocenter 6-23
    I have Beolink Passive connected to Beocenter 6-23 by full Power Link cable(8-pin),and two passive speaker Sonance connected to Beolink Passive.When I switch off my system I hear BooM in my speaker. Anybody can explain this problem, and how I can fix it. Thanks for help/
  • 10-05-2007 2:51 AM In reply to
    Re: Beolink Passive and Beocenter 6-23
    Welcome to Beoworld olegbang.
    Yes, this is a problem I have seen before when the powerlink socket is used on the passive amplifier, its a wiring fault on the powerlink socket where if my memory serves me correct pins 1 and 4 are reversed which are yellow and grey I think, but I will need to check the colours as my memory is not what it was in my younger days.
    If these are new products and still under warranty you will need to get your dealer to fix this for you. If they are out of warranty and you are happy to resolve this problem yourself, then just reversing the wires defined above will fix the problem. The signal is menn't to shut down the speakers before the TV actually switches off.
    Regards Keith....
  • 10-05-2007 2:57 PM In reply to
    Hi Keith,
    Thank you very much.Original cable B&O Power Link 8pin not worked correct,but when I made crossover Power link (1-4,4-1) Y-oooo... I really solved the problem.
    Best regards Oleg.
