hello!
Been using my new tangential deck for a couple of months and I'm very pleased with the sound. However a question in regards to possible vertical fine-adjustement of the tonearm (not antiskating).
the problems or issues:
1) When playing records, the output from the left channel is slightly higher than right channel, tried changing cartridge but didnt make a difference so I assume this is caused by the turntable/tonearm.
2) when hovering the cartridge and sometimes when descending the cartridge you can hear that the stylus doesnt track at one, i.e it "rides" on the top of the grooves before coming down/up completely.When lifting it kinda plays only right channel for a fraction of a second.
When examining the whole tonearm carriage i.e tone arm base and the speed indicator arm it seems they are slightly bent so, that the left side of the carriage is millimeters higher than the right side compared to the body. Now, as there is no errors or problems when moving carriage with the arrows I assume the sensor works ok, but I just thought that if this could be corrected someway easily without having to use much force.Tried quite easily to push the lefthand side but it didnt make a difference.Also in transport the tonearm and the speedindicator were locked with paper beneath them. Any suggestions how to correct this?
