Latest post 10-04-2007 8:23 AM by j0hnbarker. 5 replies.
Page 1 of 1 (6 items)
  • 10-03-2007 1:30 PM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    How to add pics?
    Hi i wish to add some pics to the light control thread but dont know how? or cant it be done
    Mark
    Kind Regards, Mark
  • 10-03-2007 2:48 PM In reply to
    • van
    • Top 100 Contributor
    • Joined on 10-19-2006
    • Brighton, UK
    • Posts 663
    • Gold Member
    Re: How to add pics?
    Hi Mark
    If you would like to add a picture to a thread please follow the steps below:
    1. Choose to post/reply as normal
    2. Click on the "Options" tab near the top of the compose screen
    3. Under file attachment select "add/update
    Please PM should you experience any problems.
    V
  • 10-03-2007 10:20 PM In reply to
    • Bulgarien
    • Joined on 04-17-2007
    • Denmark, Vest Sjaeland
    • Posts 201
    Or use the very easy to use Imageschack, its free and don´t use BeoWorld servers expensive memory ! opload picture, copy link and set-in, done!
  • 10-04-2007 4:13 AM In reply to
    Can you use something like a Flickr account and paste in the HTML?
  • 10-04-2007 6:56 AM In reply to
    • van
    • Brighton, UK
    • Posts 663
    • Gold Member
    Hi
    Yes you can use flickr or imageshack and follow the same instructions but paste the url rather than uploading the file:
    1. Compose message as normal
    2. Select "options" from the tab
    3. Under file attachment select "Add/Update"
    4. Enter the URL where an existing file resides.
    OR
    1. Compose mesage as normal
    2. Select the image icon from the formatting palette
    3. Enter url
    Van
  • 10-04-2007 8:23 AM In reply to
    Great - thanks Van!
