Latest post 02-02-2008 11:53 AM by d709117. 5 replies.
Page 1 of 1 (6 items)
  • 10-02-2007 4:54 PM
    BV7 STB-controller list? Where can I find it?
    Does anyone have the latest list of which STB that can be controlled by a BV7.
    Im specially looking for mac mini/apple TV and Samsung P850 which now is availible on Beo5
    Regards Ola
  • 10-03-2007 6:16 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: BV7 STB-controller list? Where can I find it?
    They are not available in the latest table version, 3.91.
    Roger
  • 10-03-2007 6:58 AM In reply to
    The Apple Remote can be added to your list by the dealer. The dealer has to come to your place and flash the PUC chip with a laptop.
    The new BV7-40 MKIII will have it as BS3 has it.
    I do not know for the other one.
  • 02-01-2008 11:42 AM In reply to
    Any news on the STB-list?
    Is there anyone that uses the Samsung DCB-P850z (or other p850-model) with a B&o TV?
    /Ola
  • 02-02-2008 11:35 AM In reply to
    Hello!
    Take a look at this: http://forum.beoworld.org/forums/default.aspx
    US
  • 02-02-2008 11:53 AM In reply to
    Sorry!
    Not right link?  Look at scandinavian forum !
    Jag har en Samsung DCB-P850ZS som går via kabel-nät (com-hem kallar den PVR 850) min BV3 har jag uppgr. stb-SW, På nr 66 finns SAMS. DCB-H360R som styr din Beo4 men man får inte ALLA funktioner ,det går även på link-tv BV6 att titta på inspelat i hårddisken o "spola" men som sagt ALLA funktioner får du inte !!
