Latest post 10-03-2007 5:41 PM by maxmaurer. 2 replies.
Page 1 of 1 (3 items)
  • 10-02-2007 2:23 PM
    BeoLab Penta: Front Panel of the amplifier
    Hello all,
    I know this is a bit superficial, but one of my BeoLab Penta's front panels will not stay closed. Whenever I am playing music with a large amount of bass the door pops open.
    Is there anyway that this latch can be replaced or modified – or should I just forget it and let it remain in the open position...
    Regards,
    Max
  • 10-03-2007 12:30 PM In reply to
    Re: BeoLab Penta: Front Panel of the amplifier
    Is that the grey panel or speaker fret you're referring to? I presume it's the plastic panel... if so, you could simply use a little blue-tack! It's hardly a pristine repair but it should hold it...
    Good luck,
     Alex.
    ________________________________________ Beowulf - the Original music aficionado...?
    Filed under: , ,
  • 10-03-2007 5:41 PM In reply to
    Haha... I figured it would come to that. I am referring to the grey panel on the bottom – on the cover of the amp.
    I think I might leave it as-is.
    Max
