Latest post 10-02-2007 2:10 PM by Alex. 9 replies.
Page 1 of 1 (10 items)
  • 10-01-2007 2:18 PM
    • Bulgarien
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Denmark, Vest Sjaeland
    • Posts 201
    New Earset 3 with switch
    The new Earset 3  with switch for music or telephone call made speciel for B&O mobile phone, more info later...
  • 10-01-2007 2:34 PM In reply to
    Re: New Earset 3 with switch
    Is it just me or does this just appear to be some A8's Photoshopped on to a photo of the Serenata? There is no picture of Earset 3 by itself. I would really like a bit more information about it.
    Nicholas
  • 10-01-2007 2:42 PM In reply to
    Have a look at B&O's Mediacenter, you get pictures of Earset 3 with the Serenata: it is just an upgraded A8 earphone set with a microphone on the wire..yet, looking at the Serenata/Earset 3 connection, I can't help wondering why B&O once again made some proprietary socket for plugging it only to Serenata (and maybe Serene), & making it incompatible with any other phone, when most manufacturers now use the standard 2.5mm jack plug..or is there once again going to be a second version of Earset 3, like the first Earset 1 Mobile was for Serene?
    Reunion Island is greeting you!
  • 10-01-2007 2:53 PM In reply to
    • Bulgarien
    • Posts 201
    The picture of earset 3  are from the official Serenata site... Why change anything when its work well Smile
     http://www.serenatamobile.com/main.aspx
  • 10-01-2007 3:53 PM In reply to
    I am led to believe that they work with the iPhone as well!
  • 10-01-2007 4:11 PM In reply to
    Sorry if I'm asking a silly question, but would I be able to plug a pair of normal A8s into the Serenata for music?
  • 10-01-2007 8:08 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Do you recall the film " Minority Report " ?
    Was not the actor Max von Sydow using a B&O A-8 to speak on the phone at home ?
    I recall ( from memory which may be a tad faded, as I don't have the DVD ) that the A-8 prop used in the movie had a piece of conical black foam attached also to the ear piece itself. Using the wire as an antennae has worked elsewhere, even in space, so why couldn't a small vox-style microphone be added also ?
    Make complete sense, and as the item platform is already in production would ( sorry, should ) cut costs. This is beginning to sound interesting.
  • 10-01-2007 8:18 PM In reply to
    • MacBo
    • Not Ranked
    • Posts 32
    Does this mean that the Serenata uses the same connector as the iPod/iPhone and can use the same dock?
  • 10-02-2007 12:22 PM In reply to
    • MacBo
    • Not Ranked
    • Posts 32
    Peter:
    Hi Peter,
    Does this mean that it will fit both the iPhone and Serenata - or that there will be a 2'nd version to fit the iPhone?
    /Bo.
  • 10-02-2007 2:10 PM In reply to
    • Alex
    • Southern CA
    • Posts 137
    second version for the iPhone like earset 1. two different plugs
    -Alex
