I agree with Alex. Absolutely no point as there are only 2 amps in most beomasters with the exception of the 1 quad model but there's not going to be enough power to adequately drive Magnepans.
If you have later Beocenters with the master link outputs I'd run them to a pair of Bryston 4Bs. I have a friend with a Magnepan and Bryston combo; it is a gorgeous combination.
Hopefully your Magnepans are in good condition. Many sell for cheap because the ribbon tweeters blow or the strings delaminate. You will hear a rattling sound when you turn the volume up if this is the case.
