Latest post 09-30-2007 4:00 AM by Peter. 2 replies.
Page 1 of 1 (3 items)
  • 09-29-2007 3:27 PM
    • Calvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • London
    • Posts 233
    Where now? What to keep, what to sell, what to upgrade?
    Well, I had a chat with the local dealer who said he'd need a few days to speak to his technical guy about this, so in the mean time I thought I'd get some forum suggestions. Basically, I have 2 seemingly incompatible syetems from the time when I had one at home and one at university, but now I have one single flat and I need to work out what to do.
    I have a Beosystem 5500, with the LP and tape player being very heavily used; hence I am very reluctant to have to upgrade this. Attached to this are 4 of my speakers, and a (non B&O) combined DVD/VCR player which run through a projector onto my wall (the sound being plugged into the Aux input on my 5500). I also have a modern setup in my bedroom consisting of a PC2 and passive kit which I run my computer music through. Ultimately, I'd like to have a Beo5 where the main options were "Phono, Tape, CD, NMusic, DVD, VCR, Light" with everything being accessable everywhere.
    What I'm after would presumably involve buying a DVD player and a VCR, but I've asked about a VCR in the past and been told that I would need to run it through a B&O television. As I have a projector though, this seems like something I can't do. Basically, I want a Beo5 set up as above, and I know that I'll need to buy some things, possible sell some things on ebay, and possible upgrade aspects of what I have. Can anyone give some ideas as to where to move to from here?
  • 09-29-2007 7:57 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Where now? What to keep, what to sell, what to upgrade?
    Are the V8000's any good? I'm not sure what to recommend with VCR's - imho it's a dodgy old format that not many people use anymore.
    Do you like the BeoSystem 4500 design? I think that with a BLink7000 would make for a lovely upgrade for your LP's and tapes.
    Do you know all about the Lintronic signal converter? Then you can do all sorts with your Beo remote.
  • 09-30-2007 4:00 AM In reply to
    Thinking off the top of my head, what about getting a Beosystem 2 video processor which can probably link to the 5500 (if you are lucky!) through a 1611 Beolink converter and this will allow you to work your projector and also, if you have the right DVD players, use a DVD controller which will allow control elsewhere. The Beosystem 2 is no longer cutting edge but is not bad at all and will be fairly cheap. Just an idea and I cannot guarantee it working, but something to think about.
