1st March February 2012
Latest post 12-16-2007 10:19 AM by Pat. 24 replies.
09-28-2007 7:19 PM
Sal
- Joined on 04-30-2007
- Indianapolis, USA
- Posts 261
Masterlink: the missing product?
Okay, maybe I'm not so adept with wire-stripping... I can admit that. But why does B & O NOT make a simple accessory, which could make them a ton of money: The Masterlink Junction Box, a TRUE masterlink junction box where terminated ML cables can be plugged in without having to strip them!
Yes, I know B & O Still make the ML Distributor, but that relegates the plugged in cables to being Link 1 through 4.
Anyone have any ideas?
I did buy up a junction box and unterminated cables recently, just because I coudn't find a simpler and less time-consuming solution.
-Sal
Love B&O, but no longer addicted.
pdoisy
- Joined on 04-17-2007
- Italy
- Posts 41
Re: Masterlink: the missing product?
You are right. My dealer always cut and split the ML cables when I add equipment, instead of adding a junction box. He says that a simple junction box does not exist and splitting cable produce better signal quality. What can I say...
Frank Rizzo
- Joined on 05-15-2007
- Posts 599
I don't really understand....It seems that the ML Distributor does the job......it will connect up to 4 ML's...yes??
Sal
- Indianapolis, USA
- Posts 261
Maybe I was doing something wrong, but when I was experimenting with the ML distributor I had laying around, the connections led to exactly what they were labeled...
Let me explain: I connected a short ML cable from my BS9000 into the AUDIO port of the ML distributor. Then out of one of the LINK 1-4 ports, I connected a longer ML cable to the Beoport Box (I have on order one long cable, but I wanted to see if it would work in the meantime, thinking the distributor would "daisy chain" two short cables into one long one). Well the Beoport Box now only responded to Link. There's something in the distributor's innards which lead it to only work in LINK setups, as such: aptly named: DISTRIBUTOR! he he he
Well, I wish there were a Masterlink "Junctioner" Box!
-Sal
There is a junction box available. I think it has 8 slots for ML. Happy to be corrected if i'm wrong. jazz
Sal
- Indianapolis, USA
- Posts 261
PLEASE let this be true!
Can anyone post an part # and price?
-Sal
Part number 3634001 no picture though i'm sorry. jazz
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
There are several different Masterlink junction boxes available from B&O and others. Below is three examples of junction boxes for wired or plugged connections
the one i've seen looks simpler than this. i'll see if i can find a picture.. jazz
Keith Saunders
- Posts 3,810
Jazz, I guess you are talking about the following available from B&O:-
Santiago
- Switzerland
- Posts 3,286
I use the white version (3132220) of the model which Keith have shown the picture just above, and it works simply great, I did myself all the connections of 4 ML cables (the maximum it supports) BV+BS+Beoport+BLActive; 30 minutes to strip carefully all the ML wires, and 5 minutes to fix them in the box. I don't know the price because it was a gift from my dealer (so I can imagine it will be really cheap )
![]() I've found the pic that i wanted to show you but i don't know how to attach it to the thread. I've emailed to beoworld so hopefully they can put it on here for me
jazz
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
And here we have it - courtesy of Jazz!
Sal
- Indianapolis, USA
- Posts 261
The picture above is what I have: the dsitributor. One can slightly make out the labels above the ML receptacles in the picture: From left to right: Audio, Video, Link 1, Link 2, Link 3, Link 4. If they weren't relegated to LINK only that would be what I am looking for.
In Keith Saunders' post above, if I see it correctly, the rightmost "junction box" has 6 ports for plugging in Masterlink cables. Is the part number that Jazz posted: 3634001 that exact box?
Will this box allow me to string together multiple shorter lengths of ML cable to make one long continuous cable, as well as split it where needed to connect to items in the same room without splicing?
Again, please tell me if 3634001 is the correct part number, and I'm calling my dealer ASAP!
-Sal
Sal
- Indianapolis, USA
- Posts 261
Santiago:I use the white version (3132220) of the model which Keith have shown the picture just above, and it works simply great, I did myself all the connections of 4 ML cables (the maximum it supports) BV+BS+Beoport+BLActive; 30 minutes to strip carefully all the ML wires, and 5 minutes to fix them in the box. I don't know the price because it was a gift from my dealer (so I can imagine it will be really cheap )
Santiago, the US retail for the small junction box is $15, relatively cheap for B & O standards, but I'll pay more for convenience any day.
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
Sal: The picture above is what I have: the dsitributor. One can slightly make out the labels above the ML receptacles in the picture: From left to right: Audio, Video, Link 1, Link 2, Link 3, Link 4. If they weren't relegated to LINK only that would be what I am looking for.
-Sal
What do you mean? the Label on the box is just a guide, it makes no difference if you plug your BS9000 in Video or Link1, link 2... it's just a junction box! Regards Stig
Sal
- Indianapolis, USA
- Posts 261
Hmmm, the results I got when plugging it in didn't give me the impression that it was purely a junction box. I'll have to try it again. -Sal
PhilLondon
- London
- Posts 2,545
If you have more than 20 m of cable in total, the big junction box, that is normally reserved for shops (so that they can easily connect and disconnect their equipments in the store) may not work. The little connection boxes connect 2 wires additionaly and provide more voltage. I have more than 20m and it works with the big box, but if you are experiencing problems with slow ML then you need at list one small junction box in the whole ML network. p.
Sal
- Indianapolis, USA
- Posts 261
Well, I'd still like to know the product number for the rightmost picture in Keith Saunders' post. THanks! -Sal
The Stig - ver. 1.7
- Posts 898
I have used one of them with 100m+ in total, no problem there...
Frank Rizzo
- Posts 599
Hi Guys...quick and really important question....for my current install.. I've got that ML Distribution box from above...and i've got to link 3 rooms plus connect my BS9000 .....is that the right box?? THanks, K
Sal
- Indianapolis, USA
- Posts 261
Frank Rizzo:Hi Guys...quick and really important question....for my current install.. I've got that ML Distribution box from above...and i've got to link 3 rooms plus connect my BS9000 .....is that the right box?? THanks, K
Seems like the easy and correct solution to me, Frank. -Sal
Pat
- Joined on 12-16-2007
- Zurich - Switzerland
- Posts 2
Hi all As new joiner, I am reading with myself with interest through the forum - and there is already a topic that concerns me as well. The background - I am operating a BeoCenter2 with a B&O Avant TV, and have the loudspeakers BL6000 and BL3 to it - now I want to have a wireless connection to my new BL3 operating in another room in the flat. The B&O shop sold me a ML distributor (the same as shown in earlier pictures in the threat with the sockets audio, video and 4 links). Usually, the ML from the TV is attached to the socket of the BeoCenter2, but then I cannot operate the wireless, if I attach the ML to the wireless one, my BeoCenter2 does not work on the loudspeakers. The ML distributor does not help much - or, do I need to attach the ML Distributor with an own ML cable to the socket of my BeoCenter2? That was not was the dealer told me... complicated? I still hope some of you has an idea. Regards, Pat
The Stig - ver. 1.7
- Posts 898
You need to connect every thing to the box with ML BC2, Avant and the Wireless (set to transmit) Welcome to beoworld
Pat
- Posts 2
Hi - thanks for your quick answer, that is service and your welcome! Now I have only two ML cables (one for the transmitter and from the Avant) - so I need a third one, and the dealer could have well told me that, as I asked him exactly that.
Page 1 of 1 (25 items)
