Latest post 10-01-2007 3:44 PM by pgerell. 4 replies.
Page 1 of 1 (5 items)
  • 09-28-2007 8:40 AM
    • pgerell
    • Not Ranked
    • Joined on 05-24-2007
    • Stockholm
    • Posts 77
    Why does the beogram 6500 lift singles with small centre hole?
    When I press play the platter starts to rotate and the record is raised by the centre adapter.
    What is the purpose of this?
    Please enlighten me!
     Thanks Peter
  • 09-28-2007 9:15 AM In reply to
    Re: Why does the beogram 6500 lift singles with small centre hole?
    It is actualy weighing the record! If it can lift it is assumes it is a 45rpm single and if it can't lift it it is a 33rpm LP
    Regards Graham
  • 09-30-2007 2:58 PM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    Thank you.
    Cool feature. I suspected it might be something like that.
    The obvious follow-up question is then:
    How can a single with large centre hole be distinguished from no record at all?
    /Peter
  • 09-30-2007 3:01 PM In reply to
    The central adapter has a lip on it which fits the large hole. It does not go all the way through so it will still weigh the record.
  • 10-01-2007 3:44 PM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    Thank you.
    After some digging in the crates I came up with a big hole 45rpm to test with.
    I'm getting more and more fond of this piece of equipment.
    Regards Peter
