These are all the codes I have. I think I lost/deleted the DVD1, but that can be unlocked by hard key on the DVD1 itself.
However, I have no idea how to obtain the codes for REG1 and REG2 and whether that code can be mimmicked on a Beo5
BeoVision 7 32"/40" 0:
Switch on the BeoVision 7 in dvd mode
- 1) No dvd in loader
- 2) Loader closed
- 3) Use the Beo4 remote to press
- 2
- REG 2 (in the list)
- Press go
- 222222005255
- Shift 0
- 5) When the first IR-code is transmitted there will appear an X on the top left side of the television screen. After 2 seconds this X will disappear
- 6) Wait 1 Second between the commands
- 7) If the X appears for a second time start all over again
- 8) Now the product is programmed to region code "0"
- 9) Do not use the region code settings in the service menu!
BC2
Program the BC2 to option 2
- 1) Put A.Aux in the List on the BC 2
- 2) Select A.Aux on the BC2 (must be in the display of the BC2)
- 3) (See No.7 Before attempting next section) Press List on the Beo4 remote until REG 2 is in the display.
- GO
- 222222005255
- GO
- 5) 1 Second between the commands
- 6) BC2 shows DISK in the display and goes back to A.Aux
- 7) Now the BC2 is programmed to region code "0"
Avant DVD & BeoCenter 1:
Switch on the Avant or BeoCenter 1 in dvd mode
- 2) Loader closed
- 2
- REG 2 (in the list) REG 1 if Phillips mechanism
- Press Go
- 222222005255
- Shift 0
10%
The Small Print:- I guess I should also caveat this information just incase anyone does get hold of the REG1 and REG2 codes that this information has been given with the best intentions possible and that anyone using such codes does so at their own risk and that any errors could cause serious faults to your equipment and possible invalidate your B&O warrenty.
