I've had this set-up for just over a year, but the BS3200 has just come back from repair. The problem after reconnecting everything up is that whenever I use my Beo4 remote control to change tracks on a CD or an album stored on the hard drive it'll skip from track 1-3-5-7 or from album 1-3-5-7 etc, and if I try to turn on the 'random' feature it turns it on and then off with one press of the button. So the Beo4 is obviously sending the signal twice instead of once with the BS3200, but seems to work fine when controlling the BV7.
I seem to remember the same problem shortly after setting up the system for the first time, but can't remember what I did, or more likely accidentally did, to resolve the problem.
Any help would be appreciated.
