Latest post 09-24-2007 5:30 PM by The Stig - ver. 1.7. 3 replies.
Page 1 of 1 (4 items)
  • 09-24-2007 11:03 AM
    • camel
    • Not Ranked
    • Joined on 09-24-2007
    • Posts 8
    Beovision 9 network connectivity
    I tried to plug in a pcmcia wireless card into the pcmcia slot of BV9 as my dealer had suggested but got nothing out of it. I dont have ethernet cables running to the BV9. Can I use some sort of wireless solution?
    Camel
    Filed under:
  • 09-24-2007 11:24 AM In reply to
    Re: Beovision 9 network connectivity
  • 09-24-2007 12:38 PM In reply to
    • camel
    • Not Ranked
    • Posts 8
    Yes I do. Hence the need for connectivity
  • 09-24-2007 5:30 PM In reply to
    You need to install the driver on beomedia, use a USBpen with the driver on. then press RED+9+0+0+GO find this line "Show service menu" and select it. Then EXIT to main menu and select "service" install the driver...
