Hi everyone,
I'm considering buying a BeoSystem 3500 (ie. Beogram, Beomaster, Beocord and Beogram CD 3500 from about 1990) to replace my ageing Beomaster 1900. I curently have the 1900 mounted on the wall and this does not need an extra bracket, as it has two slotted holes in the bottom plate that can be used to hang it onto a wall using two screws.
My worry is that the Beosystem 3500 User Manual refers to special wall brackets as an optional extra (apparently these are not included with the one I plan to buy). Can anyone tell me if the tape, CD and amp of the 3500 system can be hung on the wall without the special brackets? (ie. do they have the same slotted holes in the bottom panel?) I'm not worried about wall-mounting the turntable, as I have room for this on my record cabinet.
Many thanks in advance for your help!
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
