Latest post 09-24-2007 7:37 AM by Santiago. 9 replies.
Page 1 of 1 (10 items)
  • 09-23-2007 12:22 PM
    bv7 link tv out
    Hello everybody,
    I can't get video signal from a BV7-40 Link TV out plug.
    I have switch ON the RF modulator, plugged a external TV through a classic short coaxial cable and tried some different link frequencies, but the external tv tuner can't get ANY kind of video signal, dvd or tv.
    However this external tv works fine bypassing the BV7.
    What I'm missing or doing wrong?
    Thanks a lot in advance.
    Santiago
  • 09-23-2007 12:37 PM In reply to
    Re: bv7 link tv out
    What it the other tv?
  • 09-23-2007 12:39 PM In reply to
    Re: bv7 link tv out
    wtlc2zpx:
    A standard non B&O tv set, with analogue tv tuner.
    The built in tv tuner scanner find all tv channels when the coaxial is plugged directly in the wall.
    Santiago
  • 09-23-2007 2:04 PM In reply to
    Re: bv7 link tv out
    You need to activate the Link output by a link product! Something like beolink active or so, anything that is in option 5 or 6 can do it.
  • 09-23-2007 2:17 PM In reply to
    Re: bv7 link tv out
    This spanish thread is dealing about this... Ola!
     http://forum.beoworld.org/forums/thread/47487.aspx
    p.
  • 09-23-2007 2:47 PM In reply to
    Re: bv7 link tv out
    The Stig - ver. 1.4:
    Thank you very much Stig, I think you've exactly found the error.
    Santiago
  • 09-23-2007 2:51 PM In reply to
    Re: bv7 link tv out
    wtlc2zpx:
    p.
    Exactly! Precisely there, I'm just trying to help my friend Jordi Smile
    Thanks.
    Santiago
  • 09-23-2007 5:11 PM In reply to
    Re: bv7 link tv out
    Hello !  I'm Jordi.
    Thanks.
    I don't have another link product .. Hmm
    repeat , thanks !
    Jordi. ... format 3 , volum 55 , speaker 5 , light out , ... guauuuu
  • 09-24-2007 7:26 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Re: bv7 link tv out
    I think a beolink active may work without speakers, even if you need a terminator or something. Its probably the cheapest option for you.
    Beoaus.
  • 09-24-2007 7:37 AM In reply to
    Re: bv7 link tv out
    beoaus:
    You're right Beoaus,
    I've already tried that and beolink active (with the IR) works fine even without speakers plugged.
    Santiago
