Hi guys,
My brother has just purchased a BM 4500. It is working ok and is in reasonable condition, however the glass touch panel is loose and the top center section of the touch panel plastic frame is missing. There are some scratches on the mirrored panel.
Does anyone have the service manual?
Does anyone know if the mirrored panel and the plastic frame round the touch panel are still available from B&O?
Can anyone recommend a type of sticky foam tape to stick the touch panel back on, or is this available from B&O?
How best to clean the underside of the touch panel to remove the old tape without damaging the matt areas that sit over the sensors?
It would be great if I could get some answers to the above.
Cheers Graeme
